96 electrical problem seems to be solved
Old May 18, 2004 | 11:47 PM
DAVZKAR's Avatar
DAVZKAR
Default 96 electrical problem seems to be solved
I installed new battery bolts and cleaned terminals. My corrosion problem turned out to be a leaking positive terminal .The battery was an AC delco I installed a Die Hard and things seem to be fine now. Any body else have problems of this kind with AC delco batteries.
Old May 19, 2004 | 08:18 AM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 96 electrical problem seems to be solved (DAVZKAR)
Yeah, my original Delco leaked (mine was 8 years old). How old was your Delco that leaked?
Old May 19, 2004 | 10:54 PM
DAVZKAR's Avatar
DAVZKAR
Default Re: 96 electrical problem seems to be solved (96KICKS)
Mine was about 2 years old who knows how long it had been leaking. Not a show car so I went with the DIE-HARD. I will keep the delco in my 91 ZR-1. But will keep a close eye on it.
Old May 20, 2004 | 08:22 AM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
Wow! Two years and already started to leak. That's :bs , that should NEVER happen. What part number was on that Delco, do you know?
To 96 electrical problem seems to be solved
