Replacement door panels
Old May 21, 2004 | 01:27 PM
Jim Sitton's Avatar
Jim Sitton
Default Replacement door panels
I need to replace the door panels on my 85 coupe. I want to get the deluxe panels complete with the top trim and arm rests.
I'd like to hear from anyone who has purchased replacement panels regarding the quality and fit of the panels. Where did you buy them? Did the color match?
It looks like the price from all the vendors is about the same, around $400 per panel for the deluxe ones.
I've searched the archives but didn't really see any good info there.
Any help would be much appreciated!
Old May 21, 2004 | 04:09 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: Replacement door panels (Jim Sitton)
start checking ebay regularly :yesnod:
Old May 21, 2004 | 11:25 PM
Jim Sitton's Avatar
Jim Sitton
Default Re: Replacement door panels (brdd)
Thanks for the ebay suggestion but I'm more concerned with quality than price. Ebay kinda scares me, especially when buying something for my baby!
Old May 22, 2004 | 01:35 AM
Fast Glass's Avatar
Fast Glass
I just replaced the door panels on my '87 Convertable. I was dreading the replacement cost, but was very satisfied with what I got. The best price I found was from http://www.tld-corvette.com/index.htm. I ordered them on a Friday, and two boxes arrived on the following Wednesday. They were the deluxe door panels that came with everything installed (carpet, upper trim, arm rests, weatherstrip, defroster vents). The only thing to be done is cut the front speaker openings, and swap out the plastic door handle area from your old panels. The graphite color matched nicely, and the fit and finish was excelent. The only other thing I did to them was to add reinforcement steel under the upper trim moulding mounts. That was the first thing that separated from the old door panels. The car looks so much better with brand new panels now.
The convertable pair was $750, and the coupe pair is in the $6?? range.
Old May 22, 2004 | 10:26 AM
PAINTER MAN's Avatar
PAINTER MAN
Default Re: Replacement door panels (Fast Glass)
I bought a set from tld corvette almost two years ago. They fit great and still look great. It was an E bay purchase.
Old May 22, 2004 | 12:09 PM
Z51JEFF's Avatar
Z51JEFF
Default Re: Replacement door panels (PAINTER MAN)
I just replaced the pair in my car.There are only two companies that make these panels and ive had both.Auto Accessories Of America is the pair I finelly went with.They were o.k. as far as quality goes.One panel was cracked and then repaired at the factory.When I called to question a replacement got a little grief from the company.I went ahead and kept it,no telling what a replacement would be like.The fit was not as good on one of the panels.Anytime you bolt a bunch of aftermarket crap together its not gonna fit right.One thing that im furious about is one of my new G.M.trim pieces for the top of the door panel is already got bubbles in it where the glue has let go,its only been in the car for less than two months. :mad
Old May 22, 2004 | 12:12 PM
Z51JEFF's Avatar
Z51JEFF
Default Re: Replacement door panels (Z51JEFF)
Iv got a new set of door trim plates if you want them.This is the black panel around the door handles.84-85 are the same.
Old May 22, 2004 | 01:20 PM
kize's Avatar
kize
i also purchased new door panels from tld corvette. door panel color was right on and quality was the best that i've seen in a repo panel. i would have liked new gm originals- but pocket book says different
Old May 22, 2004 | 09:40 PM
Z51JEFF's Avatar
Z51JEFF
Default Re: Replacement door panels (kize)
........G.M. doesnt make the door panels anymore.One dealer found one for me,it was $800.
Old May 22, 2004 | 09:57 PM
Bilyk's Avatar
Bilyk
anyone still have their old med. grey panels?
Old May 23, 2004 | 07:18 PM
Jim Sitton's Avatar
Jim Sitton
Thanks for the great info guys. I'll be ordering a set from TLD tomorrow. Just wanted a warm fuzzy before laying out the bucks.
Z51JEFF how much do you want for the trim plates? I need to replace those too as both are cracked around various screw holes.
Old May 23, 2004 | 10:05 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Have you checked out http://www.vette2vette.com ? They are a Forum sponsor and have good customer seravice. If you asked for a good clean set of used ones they might be able to save you some ca$h! :hurray:
Old May 23, 2004 | 10:25 PM
86Pacecar's Avatar
86Pacecar
Got my deluxe panels earlier this year from Willcox. Great service, very happy with the parts and the prices are far better than anyone else. I paid $318 each for convertible deluxe panels.
Old May 24, 2004 | 01:01 AM
Z51JEFF's Avatar
Z51JEFF
$60 for the set,they are new.And I do had my stock door panels,graphite.The driver side is broken at the top of the door but the passenger side is still pretty nice.I think it my have a miner crack at the top.
To Replacement door panels
