Oil temp
Old May 27, 2004 | 10:21 AM
96zride's Avatar
96zride
St. Jude Donor '04 &'05
Default Oil temp
Should I be concerned about low oil temp. It never gets above 180, the coolant temp does. While crusing the oil temp is like aroung 120-130. It there a way to check the gage or sensor? 91 L98 L/T headers, Mallory ignition, Exhaust.
:cheers:
Mike
Old May 27, 2004 | 12:31 PM
PreferEuroRacing's Avatar
PreferEuroRacing
Default Re: Oil temp (96zride)
Sounds like the sensor isn't working correctly. The oil temp couldn't stay that low if your coolant is at normal temps.
