hotspots
Old May 29, 2004 | 10:10 PM
mitymek's Avatar
mitymek
Default hotspots
is this normal? there is hotspots on certain areas of my dash and also around the seat adjust switches.you can feel them with the top side of your fingers where your skins sensitive.
puzzling. on the dash theres a couple above the radio,i just figured those must be from lights,but the seat switches arent illuminated so i dont know whats going on there.
volts are normal as always.the only electrical circuit problem i know of is a dead cig lighter circuit.
when i get to work tuesday i will use the laser heat gun on em and give the actual temps.
anyone else notice this before?
