Fuel Filter?
Old Jun 21, 2004 | 11:52 PM
85RIT's Avatar
85RIT
Default Fuel Filter?
If i'm hammering on the car, it sometimes has a hesitation, then takes off. It mostly happens if i'm going through some sweeping corners hard, not at all in on a straight line. Its like the engine has nothing, just for a split second, then is fine.
I'm thinking the fuel filter may be a bit plugged, i'm figuring thats a cheap place to start. How hard is it to replace? Any tips or suggestions?
Old Jun 22, 2004 | 12:05 AM
merrick's Avatar
merrick
Default Re: Fuel Filter? (85RIT)
All you need is more gas in the tank. The fuel pump sucks in air during cornering. Also, it seems the fuel gauges aren't very accurate.
Old Jun 22, 2004 | 12:06 AM
85RIT's Avatar
85RIT
Default Re: Fuel Filter? (merrick)
I did have a quarter of a tank when it happened...must have been cornering hard!
I'll try it again on a full tank.
Old Jun 23, 2004 | 06:48 PM
myblue91's Avatar
myblue91
If you don't know the last time you changed your filter.......easy to do,look in tech tips:p:
Old Jun 24, 2004 | 10:09 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
every car I have had had more power after changing the fuel filter...alot of people neglect it
To Fuel Filter?
