Removing Pegged Emblems
Old Jun 27, 2004 | 06:48 PM
mytibt's Avatar
mytibt
Default Removing Pegged Emblems
I broke out the heat gun and the dental floss to remove the emblem, but came to find that it's a pegged emblem. With pegged emblems, do I just put a bit more Umph into it and pull it off or what manner should I approach it with so as not to damage the paint? Thanks!
Old Jun 27, 2004 | 07:36 PM
Mikez40's Avatar
Mikez40
Default Re: Removing Pegged Emblems (mytibt)
There should be nuts on the end of the pegs. Make sure you remove them first. The one under the hood is a little hard to get to. I put gum in my socket so I would not drop the nut in side the hood when I unscrewed it.
I don't think dental floss is going to help get the emblem off, if anything maybe fishing line would be better. Also you can try using a old credit card. I dought if you will hurt the pain by pulling off the emblem. I have done it several time, and never hurt the paint. I use WD-40 to remove the sticky stuff left behind. Also if you spray it on first it will losen the glue up a little.
Old Jun 27, 2004 | 07:52 PM
mytibt's Avatar
mytibt
Default Re: Removing Pegged Emblems (Mikez40)
Oh, I forgot to specify. Much like your's Mike, it's a ZR1 emblem. Do those have screws, if i reach up and under?
Old Jun 27, 2004 | 08:02 PM
Mikez40's Avatar
Mikez40
There are no nuts on the ZR-1 emblems.
Old Jun 27, 2004 | 08:09 PM
CREWZIN's Avatar
CREWZIN
[QUOTE] I put gum in my socket so I would not drop the nut in side the hood when I unscrewed it.
[QUOTE]
I lost so many of those self tapping nuts down inside the clam shell that if I ever took it apart I could make a fortune in aluminum recycling.
To Removing Pegged Emblems
