Need help fast!
Old Jun 30, 2004 | 02:52 PM
Pilot1996's Avatar
Pilot1996
Default Need help fast!
Hello all,
I posted this to the ZR-1 forum, but I haven't heard anything. My friend is driving from MD to NC in his 91? ZR-1, and is experiencing a little problem. His clutch has progressively gotten worse until he is no longer able to put it in gear. The clutch pedal goes all the way to the floor, but he can't shift. He is limping it here by stopping with it in 3rd gear, and using only 5th and 6th...we think he might be low on fluid in the master cylendar, though not sure. He doesn't want to stop totally for fear of not making it at all.
Has anyone exprienced this problem in the past or have any suggestions?
Thanks in advance,
Mac
Old Jun 30, 2004 | 03:01 PM
ruby9246's Avatar
ruby9246
St. Jude Donor '03-'05-'06-'07-'08
Default Re: Need help fast! (Pilot1996)
I had the exact same thing on my 93.
Turned out to be a leaky clutch slave cylinder.
Have him turn the engine off and see if he can shift.
If he can,then check the fluid for the clutch cylinder.
Its under the ecm module and probably empty.
Just a refil should get him to where he is going until he can check it out.
Old Jun 30, 2004 | 03:05 PM
Pilot1996's Avatar
Pilot1996
Default Re: Need help fast! (ruby9246)
Thanks, we were thinking it's a fluid thing as well, he was 29 miles away about 15 minutes ago, so we'll check it when he gets here...did you end up having to change the cylinder?
(By the way, thanks for the correction on the spelling to cylinder, it was driving me crazy and I couldn't figure it out!)
Mac
[Modified by Pilot1996, 3:06 PM 6/30/2004]
[Modified by Pilot1996, 6:51 AM 7/1/2004]
Old Jun 30, 2004 | 03:07 PM
ruby9246's Avatar
ruby9246
Yes
And they are not easy to find.
Every one had them backordered.
Old Jun 30, 2004 | 03:10 PM
Pilot1996's Avatar
Pilot1996
Alright, any suggestions on who we might try? We were hoping to leave for Myrtle Beach for the week on Saturday...nothing like a car to change your plans!
Mac
Old Jun 30, 2004 | 03:13 PM
Pilot1996's Avatar
Pilot1996
If he can...
What if he can't? Any ideas?
ruby9246's Avatar
ruby9246
My problem was few months ago. Hopefully some are now in stock.
Check with a local dealer if you are in a hurry,
If not check with Ecklers or MID america.
Good luck
Old Jun 30, 2004 | 03:16 PM
ruby9246's Avatar
ruby9246
If he cant shift it may be something else with the transmission.
From the help and advice people gave me on the Forum, it appears that this is a common occurrence with these cars. Check the fluid first.
Old Jun 30, 2004 | 03:18 PM
Pilot1996's Avatar
Pilot1996
Got it, thanks, Ruby9246, we'll let you know how it turns out.
Mac
Old Jun 30, 2004 | 04:20 PM
Pilot1996's Avatar
Pilot1996
Ruby,
You were right, we had no fluid in the slave cylinder, (right under the ECM where you said it was), refilled it, all is well.
Question: Where was the leak, and how did you go about finding it?
Thanks in advance,
Mac
Old Jun 30, 2004 | 07:56 PM
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
St. Jude Donor '06, '07, '11, '17
I am just guessing, but if you have it running and someone looking under the hood when he pushes in the clutch you might be able to see where it is leaking from, if not you might see it dripping on the ground and follow it up.
Old Jun 30, 2004 | 10:33 PM
ffvetteman's Avatar
ffvetteman
Default Re: Need help fast! (Kuehneuger)
It could also be a slow leak like I had and may be able to drive it for a while.
Mine still leaks cause I dont want to pay $110.00 for a replacement for my leaking hose.
Old Jun 30, 2004 | 11:56 PM
SPQQKY ZR1's Avatar
SPQQKY ZR1
Hey..Thanks guys! Made it in spite of the low levels of fluid in the slave cylinder. Filled er up and away we go. As far as I can see, there aren't any leaks. For now, I'm just gonna carry some extra fluid with me til I can get back home and check this thing out. Thanks for all your help and ideas.
To Need help fast!
