need fast help on jacking question
Is it ok to use a regular floor jack at the "jack points" that are under the sides of the car in back of the front tire and in front of the rear tire? This is the point where the regular jack goes. I was wondering if the regular floor jack would damage that lip under there or flex the fiberglass fender panel there and crack it. Using my floor jack would be easier over all, but I didn't want to ruin anything. Sorry for the stupidity, but this is my first Vette and I'm still a newbie to this car.
If you use some other method other than the regular jack, what do you use? MANY thanks for any assistance offered.
Brad
I have jacked my car up with the hood up, down, doors open, closed. Never had a problem yet, just make sure your doors are closed before you close your hood.
old wives tale
So I'd leave everything closed, at least until you get it up on four stable jackstands.
Brad
that have ground effect like (greenwood,motorsports) 1992 conv. I bought new tires and rims and could not find someone to jack up the car ?? than I found two co. that said they could and when I got there they said they couldn't do it ??????
Than I found someone who said he could so we tried BAD MOVE
we scratched the front first so we tried backing in and scratched the back up, then we used 2x6 but it scrapped the
sides up???? What can we do ?? I even called greenwood
about the problem but no answer??? please HELP
lay the 2x6's flat
drive the tires onto the 2x6's,you may need to buy a longnosed jack to clear that kit.dont put the jack onto the plastic part that says "jack here". it will be noticeable if you do.
look just behind where it says jack here and theres a rib.thats what you want the jack to hit on.it doesnt loook like much but its tough.
its also thin is why its best to use a puck of some sort in a common floor jacks head so you have a nice flat surface for it to hit on.i used a circular piece of 1 1/8 plywood on mine but it depends on the jack.ive also jacked it with just the standard jack with no probs.
both tires up on either side from the fron jack point,all doors hood etc closed and windows up is what i been doing just because it seems to me that the car is most rigid that way.
ive even read its recommended to crack the doors open when using a 4 point hoist on a vette.
i just cant see the logic in doing it.
