Opti swap?
Old Jul 3, 2004 | 05:54 PM
BigC4's Avatar
BigC4
Default Opti swap?
Before you answer, I know there is no hole in the manifold for a standard distributor and..blah..blah..blah....
Now having that out of the way, has anyone x'd out there optispark for a standard distributor? If so what wires are different from the standard hei type distributor?
Thank you
Old Jul 3, 2004 | 09:56 PM
bogus's Avatar
bogus
Default Re: Opti swap? (BigC4)
uh, no.
It would require a ton of work to mod the electronics.
check out the LTCC - http://www.bailey-eng.com or delteq (don't have a link) for high voltage bypass. the LTCC uses 8 LS1 coils, the delteq uses a northstar coil pack. there is a delteq for sale in c4 parts.
Old Jul 3, 2004 | 10:26 PM
mitymek's Avatar
mitymek
why would you want an old hei distributor in the first place?
Old Aug 3, 2004 | 09:43 AM
BigC4's Avatar
BigC4
I was just using HEI as a reference. I have a MSD, but the diagram references an HEI hook up. I am putting an engine in the car that is a non opti motor and wondered what I am going to do with the wiring.
Old Aug 3, 2004 | 10:16 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
You should maybe look into Diel's setup. He's got something wierd going on with it. Looks like an LT-4 with a distributor?
Old Aug 3, 2004 | 11:39 AM
BigC4's Avatar
BigC4
Where would I find that? I am still using the fuel injection, I just need a way to not use the opti.
Thank you
Old Aug 8, 2004 | 08:35 AM
Pony_Express_Driver's Avatar
Pony_Express_Driver
Go Delteq. I love mine.
Old Aug 9, 2004 | 11:08 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
When the Opti works, it works very well. I would leave it alone until it fails.
Old Aug 9, 2004 | 12:20 PM
BigC4's Avatar
BigC4
Sure I will use opti until it fails, could you tell me how and where to attach this to an older block pre 92 block.
Thank you
To Opti swap?
