Is this BS?
Old Jul 5, 2004 | 02:20 PM
jabez's Avatar
jabez
Default Is this BS?
I read somewhere on the net that this guy was bad mouthing synthetic oil and instead of using it in his vette he uses vegetable oil instead.
Is this BS or what?
Sounds like he wants to make french fries while driving.
Old Jul 5, 2004 | 02:21 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default Re: Is this BS? (jabez)
...if you read it on the net, it must be true
I would pay good money to see that experiment
Old Jul 5, 2004 | 02:41 PM
racer tony's Avatar
racer tony
Default Re: Is this BS? (*89x2*)
i think its BS, but i have heard of them using vegetable oil as a diesel alternative.... your exhaust smells like french fires
Old Jul 5, 2004 | 02:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If I were in the business of selling crate motors I'd want his address...it's not a matter of "if" rather "when".
Old Jul 5, 2004 | 02:55 PM
racer tony's Avatar
racer tony
Default Re: Is this BS? (65Z01)
yes very true, you could be laughing all the way to the bank..literaly
Old Jul 5, 2004 | 03:52 PM
ZF Six's Avatar
ZF Six
Default Re: Is this BS? (racer tony)
Sounds like he needs to lay off the crack pipe.
Old Jul 5, 2004 | 04:24 PM
Strick's Avatar
Strick
You'd probably get hungry everytime you go for a ride in it.
I remember in the old days, some guys would use Castrol R oil that was some kind of veggie oil, but it sure didn't smell like cooking oil. It did have a distinctive aroma.
Just so you know, Mobil 1 is the way to go.
c4cruiser's Avatar
c4cruiser
Is this BS or what?
Another Internet Truth The guy is full of
Old Jul 5, 2004 | 04:54 PM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
Vegetable oil? LMFAO
Old Jul 5, 2004 | 05:35 PM
amm0bob's Avatar
amm0bob
From: The last place on earth to get cable... Sacramento
There's a guy here in town with a diesel rabbit that drives it with the used cooking oil from a couple of restaurants...
But I didn't think there was a diesel vette out this way... although I have heard a story of the diesel vette... just haven't seen one myself.
Old Jul 5, 2004 | 05:37 PM
mitymek's Avatar
mitymek
now your cooking with crisco!
closest ive seen to veg oil in an engine usage is blendzall gold label "bean" oil for high performance 2 stroke mixtures.
looked like crisco if you opened a cold can.
he likely meant "mineral" oil instead of synthetic.
Old Jul 5, 2004 | 07:20 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
We installed a Jasper replacement a few years ago, it had 12 psi, they would not warranty unless it was less than 10psi.
45 minutes at 4000rpm with vegetable oil and viola, 8psi when regular oil was put back in. Maybe he is using Canola or Peanut oil....
Old Jul 5, 2004 | 10:06 PM
vetteseniorcit's Avatar
vetteseniorcit
As I remember, a long time ago (ahem) some folks ran castor oil as a "break-in" oil on a new motors. They were low compression in-lines (Plymouth, etc.). I thought it was BS then, and I believe it is BS now. Would I put ANY half-baked idea into my LT1? Not hardly, Pilgrim! I run what brung me; Mobil 1.
[Modified by vetteseniorcit, 7:07 PM 7/5/2004]
Old Jul 6, 2004 | 04:10 AM
1996blklt4's Avatar
1996blklt4
Default Re: Is this BS? (vetteseniorcit)
Actually vegetable oil outperforms Mobil 1 by far. I use Mazzola in the winter and Crisco in the summer
Old Jul 6, 2004 | 04:11 AM
1996blklt4's Avatar
1996blklt4
Default Re: Is this BS? (1996blklt4)
Old Jul 6, 2004 | 05:14 AM
skeet's Avatar
skeet
That is BS and most likely started on the Corvetteforum by some mustang owner who would like to stand a chance to bet us.
However, you can fry your french fries in Mobil 1 and serve them for free to your mustang owner friends. I understand they go down real easy.
Old Jul 6, 2004 | 09:07 AM
smokeyburnouts's Avatar
smokeyburnouts
sounds crazy. i know from being involved in motocross that there are oils that r very similar to cooking oil. i ran them a few years back. it is castor oil. it smelled weird when it burned (2-cycle), definatly different from regular synthetic blends. now i'm sure this oil i'm talking about is different from what would run in vettes, but there may be some truth to what this guy is saying. but why wouldn't u want to just run the mobil 1 synthetic anyway?
To Is this BS?
Old Jul 6, 2004 | 09:30 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Is this BS? (skeet)
Probally easier to swallow than crow.
Old Jul 6, 2004 | 09:44 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Castor oil is a vegtable oil (from the castor bean) and is one of the finest pure lubricants available. Unfortunately, it has too many drawbacks to make it a viable alternative to our modern synthetics.
You COULD run it in a Corvette under ideal conditions, but I sure wouldn't.
Larry
Old Jul 6, 2004 | 09:49 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: Is this BS? (code5coupe)
