I just found the key Fob for the 94 vert, changed the battery and it works. But it just unlocks the doors and pops the hatch. how do you get it to lock the door? or is it only for unlocking the doors?
To switch the setting from opening driver door to both doors insert the ignition key but don't turn on. With the fob in range hold the door button for more than 2 seconds. The door locks will recycle.
To turn the PKE(Passive Keyless Entry) on or off take keys out of ignition and hold door buton for longer than 2 seconds.
