Distributor Tool
Old Jul 5, 2004 | 05:23 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Distributor Tool
Well, picked up a distributor tool for the 87/L98, she's running fine but wanted to adjust the timing from 6 BTC to 7 BTC .... anyway, with the tool i can't get movement ... seems like the foot is way to long and the metal tube from the maniforld is in the way... is there a special distributor wrench that i should be using... thnaks guys , vinnie
Old Jul 5, 2004 | 06:09 PM
Pete K's Avatar
Pete K
Default Re: Distributor Tool (vinnies87)
A 3/8 ratchet with a 6 inch extention and a swivel(universal) connected to a 9/16 socket will get the job done.
Old Jul 6, 2004 | 11:59 AM
89C4's Avatar
89C4
I thought by "distributor tool" you meant the distributor wrench.
Yes, there is a special wrench that is offset; looks like a long "L". The "9/16" nut/bolt end is the short end. I bought one at a local swap meet a while back; invaluable in my opinion.
You can pick one up at any tool or auto parts store.
Old Jul 6, 2004 | 12:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have one of those tools from Sears and it indeed works, though I only get 1/12 rotation at a time.
I need to angle the tool slightly while pressing it toward the weather strip on the firewall. Then there's just enough room to rotate it 1/12 turn before it hits the vent tube comming up from the intake base.
Though it's tedious to use, that tool does work.
Old Jul 6, 2004 | 06:34 PM
89C4's Avatar
89C4
Default Re: Distributor Tool (65Z01)
I only use it to break the bolt loose, enough to rotate the distributor. To remove distributor, I reach in and unscrew the bolt by hand, after everything cools down.
Its one of those tools that when you need it, you need it; otherwise, it just sits in your toolbox.
To Distributor Tool
