'87 vert operating temp
Old Jul 8, 2004 | 05:11 PM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default '87 vert operating temp
What's a normal operating temperature for an '87 convertible?
Old Jul 8, 2004 | 05:19 PM
Wheelman's Avatar
Wheelman
Coolant temp should be between 185-230, oil 185-230 depending on the outside air temps A good thing to shoot for when doing cooling mods is coolant temp of around 185 and oil temp of around 200
Old Jul 8, 2004 | 05:37 PM
F22Trainer's Avatar
F22Trainer
Default tell me more
I AGREE - so how'd ya do it?
Old Jul 8, 2004 | 05:55 PM
C-4 Cross Fire
My friend with the vert said the Chevy dealer mechanic told him that normal operating temp is 240 and that if he didn't believe him he could go see him and he'd show him the book. He shoulda gone to look at the book, I'd say!
At 240 your tranny seals begin to fail!
Old Jul 8, 2004 | 05:57 PM
Square's Avatar
Square
My 86' coupe came with a 160 degree Thermostat, and if it is moving above 40MPH, even in muggy 90 degree weather, it will still pull the coolant temp down to the low 180's(on the highway it will pull it down even more). I just got the car, and I haven't had a chance to clean the radiator, so I think a lower T-stat might be a good start.
Old Jul 9, 2004 | 02:08 AM
silverja's Avatar
silverja
Default From Corvette Specs
The thermostat opens at 195 F and the Fan Motor Switch Point is at 223 F. My 87 Convertible normally runs 200 - 205 Farenheit and while sitting in traffic for a few minutes runs up to around 230 F at most. These readings are for a hot summer day and fluctuate 10 - 15 degrees downward on a cool summer day or in Spring and Fall.
Old Jul 9, 2004 | 08:34 AM
Cal Vette's Avatar
Cal Vette
Default My 92 runs at 197-203
I have never seen temps even close to 220,even in very hot weather!
Old Jul 9, 2004 | 09:45 AM
vader86's Avatar
vader86
Preferably 195-215 oil, and coolant a little lower than that.
Mine tends to run 200 and 180
To '87 vert operating temp
