cannot find A/C Vacuum thread. help please...
Old Jul 16, 2004 | 02:17 PM
mustbampeg's Avatar
mustbampeg
Default cannot find A/C Vacuum thread. help please...
hey guys i have spent all last night and this morning searching the archives for the thread that posted links and even had detailed instructions on how to trouble shoot my 96 LT1 A/C problem of only blowing through the floor or defroster.
any help on this would be greatly appreciated.
thanks,
randy
Old Jul 16, 2004 | 06:14 PM
corvette-pilot's Avatar
corvette-pilot
Mine turned out to be this check valve.
It is under the passanger side fuel rail cover.
You also will know it is this if you cruise control doesn't work as this too controls it. Hence the "T"
Old Jul 16, 2004 | 07:03 PM
MostWanted's Avatar
MostWanted
That is the exact "T" that was loose when my AC wasn't blowing out of the main vent.
Old Jul 18, 2004 | 01:48 PM
mustbampeg's Avatar
mustbampeg
my check valve is good. the cruise also works good. i need help to find the thread or for someone to please re-post the directions for checking vacuum at the HVAC controller and/or determining if the HVAC controller is the culprit.
thanks,
randy
Old Jul 18, 2004 | 01:57 PM
1Patriot's Avatar
1Patriot
Spent some time last year trouble shooting the AC on my 96 LT1 HVAC system and it was the AC Controller. Replaced the little balck box and all is well. By the way, the "T" on my engine was OK and the Cruise Controll worked just fine also. Also the vacumn to the storage tank was also fine. After tha, it was just the removal an replacement of the AC Controller that worked.
Hope you are flexible and have small hands.
Old Jul 18, 2004 | 02:05 PM
mustbampeg's Avatar
mustbampeg
where is the AC Controller and how much did it cost? small hands? well not really, i guess if i was a lesbian, i would be 'well hung'
anyways, thanks,
randy
Old Jul 18, 2004 | 10:53 PM
1Patriot's Avatar
1Patriot
The AC controller is located behinf the dash on the firewall slightly to the left of center, After removing the hush panel, look above on the left of the air outlet duct which is in the center. One captive screw holds it into position along with 2 tabs at the top, if I recall correctly. There is a cluster of vacumn lines attached and an electrical cable attached to the controller.
The maintenance Manual says it is below LH I/P, right of steering column on bulkhead.
To cannot find A/C Vacuum thread. help please...
