Fuel Pump RELAY
Old Jul 17, 2004 | 08:49 AM
ravenlunatic's Avatar
ravenlunatic
Veteran: Marine Corps
Default Fuel Pump RELAY
Can someone please tell me where to find the fuel pump relay on a 96 LT1 and also how to troubleshoot it? Thanks for all replies, I'm having an intermittent problem that is getting really annoying.
Old Jul 17, 2004 | 09:57 AM
rick lambert's Avatar
rick lambert
Hope you got my email, but ON AN 87 it's next to the wiper motor-hope there the same.
Old Jul 17, 2004 | 11:47 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm not sure about late LT1s but all L98 use the FP relay only to prime the fuel rail at startup.
The oil pressure switch is the only power link to the fuel pump after that.
Old Jul 17, 2004 | 03:04 PM
ravenlunatic
looked next to wiper motor and do not see it. Anyone else?
Old Jul 17, 2004 | 06:29 PM
ittlfly's Avatar
ittlfly
I believe the fp relay for my 92 is uner the right side dash board.....mounted on a block with several other relays. Let me know if you want the exact location but it will be for a 92.
Old Jul 17, 2004 | 07:49 PM
ravenlunatic
How do I remove he right side trim plate. I only see the one screw underneath?
Old Jul 19, 2004 | 04:45 PM
ravenlunatic
Default Thanks for all the help
After the relay checked good I changed the fuel pump. Problem fixed
To Fuel Pump RELAY
