Dim dashboard lights
Old Jul 21, 2004 | 07:21 PM
Wesonoil's Avatar
Wesonoil
Default Dim dashboard lights
undefined
I have an 86 that the dashboard lights just got dim. They have been fine. I have checked all fuses and the reostate. Still very dim. Anyone?
Old Jul 21, 2004 | 10:12 PM
TaylorMutts's Avatar
TaylorMutts
Are there any other symptoms? Any chance the high beam indicator and both turn signal lights are on? If that is the case, then you have a bad ground. OR, could be the bulbs in the dash itself are out. Run a search through the archives for "digital dash" topics. There are some good links with repair suggestions for the digital dash. I just recently repaired mine, and the only expense was for four new bulbs and a little bit of my time.
Good luck!
Old Jul 21, 2004 | 10:36 PM
kize's Avatar
kize
Could be a bad photo eye on the cluster. Also the headlight switch controls the brightness and could have a flat spot on the pot. Things to check.
Old Jul 21, 2004 | 10:37 PM
Wesonoil's Avatar
Wesonoil
Thanks Taylor...No other symtoms other than the dash thingy. This just happened yesterday. The dash lights were fine before. I'll do a search on "digital dash"
Thanks for the info! :-)
Old Jul 21, 2004 | 10:40 PM
Wesonoil's Avatar
Wesonoil
Thanks Kize...I'll check that one!
To Dim dashboard lights
