Jacking an '88
Old Jul 26, 2004 | 08:43 AM
rws.1's Avatar
rws.1
Default Jacking an '88
I'm sure that this has been asnwered many times before, so I'm sorry for the repeat.
I know that to jack my '88, I need to position the floor jack between the arrows marked on the body ahead of and behind the door.
My question is: Do I actually jack on the edge of the body or do I have to catch a piece of the frame with the edge of the jack in behind the body and ensure that there is no weight on the edge of the body??
Old Jul 26, 2004 | 08:50 AM
shotchkiss's Avatar
shotchkiss
Make sure you catch some of the metal behind the rockers, it is what holds the weight of the car. The rockers may flex some, that's ok. Also watch out you not lifting on the fuel or brake lines while your jacking.
Old Jul 26, 2004 | 09:45 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
All depends on your purpose for jacking. I jack the front up by first driving up on some 2 x 8's and sliding the floor jack under and jacking by the crashbar or K frame, then place floor jacks where the swaybar mounts to the frame.
For the rear I use a jack-a-vette to lift the car by the diff, or if that is not available, place a 4 x 4 on your floor jack and jack it up by the spare tire(as close to the diff as possible).
For jobs that don't require removal of the wheels, I use ramps(not Rhino Ramps which don't get you high enough). Use 2 x 8's on the ramps to decrease the angle and you'll be fine.
Old Jul 26, 2004 | 09:53 AM
vader86's Avatar
vader86
Be sure the jack catches a piece of the frame between its indentions when you use floorjacks.
Some people say to pop the hood, open all doors and the rear hatch when you jack the car. Do that if you want.
Old Jul 26, 2004 | 10:16 AM
Mr Mojo's Avatar
Mr Mojo
I leave everything closed. Never had a problem yet, but if you remember the other jacking post, one guy complained he cracked his top and he had the hood and doors open, and that was on a two post lift I think.
Old Jul 26, 2004 | 10:15 PM
newbecorvetteguy's Avatar
newbecorvetteguy
These look like pretty good instructions.
QUESTION: What is the best way to jack up a ZR-1?
ANS: Do not jack a C4 at the center of its side frames. If you do, the biggest risk is cracking the front glass.
There are only two places to properly lift a C4 with a floor jack.
At the front, you lift on the crossmember just ahead of the engine. It is best to use a block of wood (4x6x1.5 works best) on the jack pad. Many C4s will have to have their front wheels driven up on blocks (12x2x2 works good) to get the jack under the car. Once you're up on the blocks, turn the wheels to full lock and come in with the floor jack behind whichever tire is turned in. Only floor jacks with long, low frames typical of 2-ton jacks will be able to do this. It works very well if you have the right floor jack and a block of wood.
You also can come in from the front with the floor jack but then the blocks you drive the front up on must be much higher.
At the rear, you need the "Jack-a-Vette" tool. It bolts to the jack pad and its vertical leg goes between the exhaust pipes and lifts on the rear axle housing. This method is not documented in the factory service manual but had been used in the service trade for many years and, according to the makers of Jack-a-Vette, was used at Bowling Green during the C4 era. On cars that are lower than stock, the rear may have to be driven up on blocks to allow enough room to get the floor jack and Jack-a-Vette underneath.
To support a C4 on jack stands, place the stands on either side at the front right where the frame turns inward behind the front wheels. At the rear support the areas of the frame just ahead of the rear wheels. In all cases, I use small blocks on the jack stand pads. Take extreme care to avoid crushing fuel or brake lines.
Thanks to Hib Halverson for this info.
corvette questions
Old Jul 27, 2004 | 11:06 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Tell me more about this jack point at the spare tire location. Is it safe? Should I take the plastic cover off the spare first? I am really sick of lifting thecar by the side rails... they are so thin and they are getting chewed up by the jack (my jack sucks).
PS... what is the crashbar/k-frame? Is it the obvious piece between the front tires?
To Jacking an '88
