dumb question?
Old Jul 27, 2004 | 04:10 AM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
Default dumb question?
I shut the driver's side door today and the trim on the door came loose. I noticed that the 'bolt' on the trim is threaded and I heard something drop, is that a nut or what? Also, any tricks to getting the trim back on without a whole lot of trouble?
Old Jul 27, 2004 | 09:31 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Sounds like you'll have to pull the door panel and retrieve the "nut". No shortcuts.....
Larry
Old Jul 27, 2004 | 12:45 PM
vettebldr1's Avatar
vettebldr1
Actually, the only place the trim is held on with nuts you can get to without pulling apart the door, so if its one of the end ones, just get a black nut that will fit. The center of the trim is held in place with little clips like this
Hope that helps out a little
To dumb question?
