How do you clean ................
Old Jul 31, 2004 | 05:09 PM
franki's Avatar
franki
Default How do you clean ................
Recently bought an 86 coupe. Engine compartment looks as if it had been "detailed" in past with one of those spray on glossy liquids that now has turned brown crusty looking.
Anyone have any recommendations of how to get this off engine parts, hoses, weatherstripping ??????
Old Jul 31, 2004 | 05:13 PM
xlr8nflorida's Avatar
xlr8nflorida
I'd probably use some simple green diluted in water.
Old Jul 31, 2004 | 05:14 PM
NightFlight's Avatar
NightFlight
Simple Green, rinse; repeat if necessary
Old Jul 31, 2004 | 05:25 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Oh don't you just love the work of shlock detailers? If the basic cleaning doesn't get it all, a good steam cleaning may be called for. Watch the critical areas and you'll be fine, just did my LT1s underhood for the umpteenth time last night which some cringe at the thought of!
Old Jul 31, 2004 | 05:49 PM
RED-85-Z51's Avatar
RED-85-Z51
I tied shopping bags around the MAFS, AIR PUMP, DISTRUBUTOR, and ALTERNATOR.
I emptied a whole bottle of Simple Green Automotive Degreaser all over the whole engine. Down in from of the wheel Wells, everything. Then hosed the whole thing off, then uncovered, let sit a while, then started it up.
It ran rough for a bit, but after a few runs, it was normal, and a whole lot cleaner.
Old Jul 31, 2004 | 06:22 PM
lmac2's Avatar
lmac2
I just finished cleaning my engine compartment, I used Knights Spray Nine Greeze-OFF. It worked very well and removed any old Armor-All or other treatments put on the engine. One word of caution, it seems to be pretty strong stuff, so use care around decals, engine compartment stickers etc. BTW it was extremely good cleaning the grime off the suspensions components. Good luck!
Old Jul 31, 2004 | 09:03 PM
franki's Avatar
franki
Thanks for the help. Will try some of these things this coming week.
Old Aug 1, 2004 | 01:14 PM
Corvette Kid
That sounds like something I've been looking for to get those A arms and stuff looking nicer since I'm too lazy to scrub them! Where can I get some?
Old Aug 1, 2004 | 02:04 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Yeah; the dealer where I bought my `87 must have sprayed a 55 gal. drum of that crap under the hood,& on all the interior plastic pieces. Glad to see I`m not the only one.
Old Aug 1, 2004 | 03:47 PM
PSO3120's Avatar
PSO3120
Can you hose down an Opti-Spark engine as long as you cover the Opti with plastic?
Old Aug 1, 2004 | 03:54 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Simple Green rules...
Old Aug 1, 2004 | 04:06 PM
Corvette Kid
I won't speak for all optis but mine is a later, vented one, new and the vacuum hoses are new and connected. I'm not concerned with water getting to it under normal circumstances. I don't cover it but nor do I spray water directly in that area. I have washed or steamed cleaned my engine many times with no problems.
To How do you clean ................
