G92 Performance Axle
Old Aug 1, 2004 | 10:35 AM
Bill713's Avatar
Bill713
7th Gear
Default G92 Performance Axle
How can I tell if my new (new to me) 1984 Corvette has the performace Axle option?
Thanks!
Bill
Old Aug 1, 2004 | 11:03 AM
DAVZKAR's Avatar
DAVZKAR
Check the glove box or the rear compartment the code is as you know G92. If it is a stick car it will be different.
Old Aug 1, 2004 | 12:51 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
Check for the RPO sheet in one of the rear compartments. Also check for RPO G44 as well as G92.
Otherwise, just tell us what rpm you're turning at freeway speeds
Old Aug 1, 2004 | 02:20 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Re: G92 Performance Axle
DAVSKAR and JSA 007 are correct. G92 was fairly rare in 1984 - about 9% of A4s, if I'm reading my stats correctly. Percentages edged up over the L98 years -
1985: 18% of A4s
1986: 17%
1987: 28%
1988: 24%
1989: 46%
1990: 60%
1991: 23%
Old Aug 1, 2004 | 02:41 PM
Bill713's Avatar
Bill713
7th Gear
it is a 4+3 trans... I am walking out to the garage to check now. it is not on the road yet so I can not get the rpms for you.
Old Aug 1, 2004 | 02:52 PM
Bill713's Avatar
Bill713
7th Gear
I have a bunch of 3 letter combos but nothing starting with a "G"... bummer.
Old Aug 1, 2004 | 03:01 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Help me more experienced C4 folks: is the C4 like the C5 in that all manuals get a relatively high axle ratio as standard but automatic folks have to order an optional ratio to get the fast ratio?
Old Aug 1, 2004 | 06:30 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
My knowledge is spotty but generally speaking, I believe you're correct. With the 84s, I think both the manual and ATs had 3.07s, and ALL were Dana 36s. The 84 performance axle was a 3.31 which I was told was only potentially available with the Z51 option. Apparently, the Z51 normally came with 3.07s wich is why the Dana 36 3.31s are so rare (only 410 ordered according to CAC)
Old Aug 1, 2004 | 06:36 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Always learning on the forum...thank tobijohn!
Old Aug 1, 2004 | 06:40 PM
tobijohn's Avatar
tobijohn
Bench Racer
Sure! One other thing I forgot to mention. As far as the manuals having relatively higher axle ratios, the 85-88s I think only had 3.07s....
To G92 Performance Axle
