changes in ltpws
Old Aug 2, 2004 | 10:12 AM
rganders's Avatar
rganders
Default changes in ltpws
What year did corvette change the low tire pressure warning sensors from the band type to the type that has the valve stem mounted in the sensor module? Can you replace the old type low tire pressure warning sensors with the new type if you also change out the receiver module in the dash? Thanks Randy Anders
