Targa squeaks.
Old Aug 3, 2004 | 11:29 PM
Spike13's Avatar
Spike13
Default Targa squeaks.
My targa top on my 91 squeaks pretty bad at low speeds, is there anything I can do ??
Thanks for the Help!!
Spike
Old Aug 3, 2004 | 11:52 PM
DukeDiablo's Avatar
DukeDiablo
I suppose you could try cleaning the weatherstripping with some silicone or petroleum that will lubricate it as well.
I'd check all the hardware for anything loose too.
Old Aug 4, 2004 | 12:09 AM
NightFlight's Avatar
NightFlight
Try cleaning the weather stripping and applying some petroleum jelly (apply and wipe down with dry cloth). Did this to the T-Tops on my mom's Iroc a couple of years back -- haven't squeaked since.
Old Aug 4, 2004 | 07:14 AM
HTRK-1's Avatar
HTRK-1
You might try these....
http://www.madvet.com/shop?frame=3.762
Old Aug 4, 2004 | 09:55 AM
runner140*'s Avatar
runner140*
Default Stop the squeak
Ecklers makes an inexpensive teflon or plastic strips for squeaking targas. I saw them in this months catalog. Check them out.
Old Aug 4, 2004 | 12:07 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
If you tighten the back bolts first and then the front it sits better.At least on mine.thouse felt pads help alot to.
Old Aug 4, 2004 | 11:43 PM
Spike13's Avatar
Spike13
Default targa
Okay guys, thanks for the replys, I will try to clean the weather stripping first and then order the parts if needed. I appreciate the advice!!
Spike
Old Aug 5, 2004 | 08:17 PM
lspalding's Avatar
lspalding
Make sure the bolts holding down the mounting brackets on the front header of the top are tight. That's where my squeaks were, and they never came back.
Old Aug 6, 2004 | 12:02 AM
95Torch's Avatar
95Torch
You could also try cutting some velcro and adhere it around the top of hole where the screw protrudes out, then tighten up...Works like a charm.
To Targa squeaks.
