Never Should Have ...
Old Aug 5, 2004 | 08:42 PM
NightFlight's Avatar
NightFlight
Default Never Should Have ...
tried to change my starter. I have to start at the beginning.
It started few months back, every once and a while when I went to start my car, all I would get was a click and nothing. Two or three minutes later, turn the key and she'd start right up. Battery was fine (almost new), connections seemed to be OK and would normally only happen when the car was hot. I'd run to the store or have to do some running around for work and when I'd come back, nothing. This would happen randomly and some times would go weeks without happening.
Also, a couple of weeks back, every once in a while I'd notice a small spot (size of a quarter) of anti-freeze in my car port. Checked all the obvious suspects (radiator, hoses) nothing -- and it would'nt happen all the time. Unrelated to the starting problem until today.
Today, I go to our local auto hobby shop, which has a lift, to replace the starter -- thinking it was going. While I have to tell you getting a starter out on a twin-turbo is no easy task; but after getting it out, I compare it to the one I had bought at Checkers -- they gave me the wrong one -- a little bigger and wrong gear teath
Oh it get better, examining one of the hoses going into the turbo on that side I notice a very small drop of antifreeze where it connects into the fitting. Thinking all I had to do was adjust and tighten the clamp holding it on, I did so.
Put the old starter back in, didn't want to leave it at the auto hobby shop over night and it was getting close to closing time. Got in and started the car -- steady stream of anti-freeze started flowing from the braided hose. Immediately turned it of, called a flat bed and had towed to a local shop for repairs
I know this is a little long, but I just needed to vent a group who could relate ....
Old Aug 5, 2004 | 09:46 PM
FX GS's Avatar
FX GS
Sometimes what seems like the simplest........................
Old Aug 5, 2004 | 10:01 PM
GiDvEtTe84's Avatar
GiDvEtTe84
We have all been there at one time or another. Sorry to hear.........
Old Aug 5, 2004 | 10:13 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Try to see it as a blessing, your getting your starter prob out of the way and found your leak..all in a safe and controlled environment. That leak could have reared it's ugly head on a highway trip miles from home at midnight on a sunday, or worse yet in a hostile neighborhood or in bumper to bumper traffic on the freeway.
It sucks to have problems but in this case you should see the positive.
Old Aug 5, 2004 | 11:05 PM
NightFlight
Thanks, that's exactly what I told my wife. We frequently make 370 mile trips from Salt Lake, UT to Mesquite,NV to visit family ... most of the trip is through 'no-mans land'. If it happened out there on a 100 plus day, no cell reception -- I don't even want to think about it.
Old Aug 6, 2004 | 08:17 PM
NightFlight
I just got off the phone with the folks working on my Vette -- some good news. The hose going into the turbo was split up the side under the stainless braid. So they are replacing it (had to order some that didn't get there until late this afternoon, it wont' be ready until Monday). Just glad we found it now and not out on the open road.
I also had them replace my starter and check my battery (positive side mount was stripped). So they're replacing the batter and cables (my request).
What makes all this really good news, is all of this is being done for just under $500 (parts and labor). I know if I had a lift (and some time), I could have done it for a lot less; but $500 seems pretty reasonable to me.
Old Aug 6, 2004 | 09:01 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Good thing to check all your hoses - a lot of the guys have changed theirs recently as they become brittle from the (turbo) heat...
Also, The Starter motor is a Callaway specific part - they gave you a starter for an 87 vette, not an 87 Callaway
As I have suggested to others, pull your starter and take it to a shop local to you and get it rebuilt (the ones you buy at parts stores are rebuilt anyways, right...)
Hope this helps
*89x2*
www.callawayownersgroup.com
Old Aug 6, 2004 | 09:20 PM
NightFlight
89x2, thanks for the info ... now things make sense. I'll be taking the starter I bought last week back down to Checkers tomorrow.
According to mechanics when I talked to them, they've already had the new starter in. I'm guessing they were able to find a good replacement; But I'll be calling them first thing Monday morning to make sure.
As far as my hoses go, I just had new turbos installed, along with new hoses about 7 months ago, at another shop. I wasn't real impressed with all of their work (a little lack of attention to detail), and now I'm thinking the problem with the hose may have been from improper installation -- it was split from the end up. Can't say for sure, just happy it's being fixed.
Old Aug 6, 2004 | 09:24 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Aug 7, 2004 | 10:42 PM
*89x2*'s Avatar
*89x2*
You are welcome We (fellow owners and I) were discussing your B2K and the starter - it was mentioned to rebuild the one you have - look inthe yellow pages for this service if you don't know of one
To Never Should Have ...
