Frisbee Help
Old Aug 6, 2004 | 02:42 AM
MrArmyAnt's Avatar
MrArmyAnt
Default Frisbee Help
I have a 94 Auto, assuming it has the l98, but it will have the newer thin frisbee. will i still get the same horse gain removing it?
Old Aug 6, 2004 | 04:19 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
In 1992 the LT1 was introduced and the L98 was laid to rest. Unless someone has replaced your 94's engine with the earlier L98, you have an LT1 with an opti spark distributor and a gear driven waterpump with no frisbee. I dont own one but I'm looking at a pic and I dont think I see a frisbee of any sort so be careful that you dont remove a belt tensioner or something important.
Old Aug 6, 2004 | 07:50 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
What he said.....
Old Aug 6, 2004 | 10:45 AM
MrArmyAnt's Avatar
MrArmyAnt
so, in the forums opinion, which engine was faster?
Old Aug 6, 2004 | 11:33 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed the frisbee only came on the '88-'91 Vette L98.
The late L98 Vettes were low 14sec to high 13sec cars; the LT1 Vettes were low to mid 13sec cars, gearing being the same.
Old Aug 6, 2004 | 02:34 PM
JCD's Avatar
JCD
The 1992 corvette was the first to have 300 base HP since 1970.
Old Aug 6, 2004 | 03:12 PM
byte_me's Avatar
byte_me
in this order- l98, LT1, LT4 and ZR1's LT5 (maybe- some LT4's are higher HP then were rated)
I also have a 94 but a vert auto- indeed it has an LT1 engine...300HP 340Ft\Lbs of torque. I came off an L83 in an 84...and let me tell you...LOL it scared me when I jumped on this LT1...I mean, I was used to 205HP!
To Frisbee Help
