Help needed with battery drain problem
Old Aug 9, 2004 | 02:03 PM
PSO3120's Avatar
PSO3120
Default Help needed with battery drain problem
My battery is pulling a drain from somewhere and I am unable to locate it. With a test light on the battery terminal I am getting a steady glow even with all, (yes, even those sneaky ones under the dash), the fuses and relays pulled. Anybody have any ideas where this could be coming from? 1992 LT-1 6-Speed Thanks -Michael
Old Aug 9, 2004 | 03:32 PM
redwing76's Avatar
redwing76
Test lamp hooked to the positve and the neg disconnected, with the other lead connected to the negative cable?
Old Aug 9, 2004 | 03:39 PM
PSO3120's Avatar
PSO3120
Ahhh, I was doing it wrong. Thanks!
Old Aug 10, 2004 | 12:23 AM
comp's Avatar
comp
did the light not glow ???????
Old Aug 10, 2004 | 08:00 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
You'll never get anything with the negative cable disconnected from the battery and the test lamp connected between the positive terminal of the battery and the (disconnected) negative cable.
How long does it take to discharge? You may just have a weak cell in the battery. The battery can discharge itself if there's internal short. Have it tested before you do anything else.
Old Aug 10, 2004 | 11:27 AM
redwing76's Avatar
redwing76
A friends 93 would discharge the battery thru the secuirty light after 4-5 months of a Minnysnowda winter.
You need a volt meter Radio Shack has a good one for about $29.00.
If you test a battery at both the positve and the nagative terminals all you doing is reading battery voltage.
With a meter you can tell the rate of discharge but not the source of the discharge.
How long does the car sit?
How long before discharge?
Is the battery all the way up?
How old is the battery?
Is it dry?
Old Aug 10, 2004 | 03:10 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
This is not real common but I have seen a defective alternator that charged well, but then discharged the battery when not running. To check, put all your fuses back in, make sure battery has a good charge and is hooked back up, then simply unplug all wires to alternator and see if battery still drains over night. I've seen it several times. This is all assuming that you have had your battery load tested and know it has no dead cell.
To Help needed with battery drain problem
