Transmission help.
Old Aug 9, 2004 | 08:03 PM
Bugleboy84's Avatar
Bugleboy84
Default Transmission help.
I've posted a same tread at Tech/Perf, but I wasn't getting any response. I'd thought maybe I can get some attention by putting the post here. Please help.
I have 89 Corvette coupe, no modifications. Automatic transmission.
It has 105,000 miles. And as far as I know, the previous
owner didn't service the car at all. Which ticks-me-off.
I've been left with his burden.
Anyways, the shifter works fine.
I have checked the transmission fluid, and also is fine.
When I drive-off, I can feel it shifts to about 2nd or 3rd gear.
Then when I go to about 40mph it should already have shifted to
final gear. But it didn't. It keeps at 3rd.
Also, I noticed that it doesn't accelerate as usual.
Can anyone help out? I know I can count on you all.
Old Aug 9, 2004 | 09:39 PM
Bugleboy84's Avatar
Bugleboy84
Old Aug 9, 2004 | 10:05 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
No, it sounds like you bought his burden. First thing I would check is the TV cable adjustment. That's probably not the problem, because they usually don't just go out of adjustment unless they've been fooled with. But it doesn't cost anything to check. Who knows, it might have stretched. You could also have a varnish buildup on the throttle valve. If that's the case, you could run an additive through it, then change the fluid and filter after the additives been in for a few hundred miles.
Old Aug 10, 2004 | 07:51 AM
chucks88's Avatar
chucks88
Default 105k
But with 105K on the clock be prepared for a rebuild. Mine Schit the bed at 117K or so.
Old Aug 10, 2004 | 09:18 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Not sure, but it sounds like it's not going into OD. It may be the solenoid that controls that. A good transmission shop that you trust should be able to diagnose quickly for you.
Old Aug 10, 2004 | 11:18 AM
redwing76's Avatar
redwing76
It might be the shift valve is dirty.
What does it do on the hiway at 55-65 mph, rpm?
Does that trans have an accumulator?
Old Aug 10, 2004 | 11:39 AM
96zride's Avatar
96zride
St. Jude Donor '04 &'05
Mine pooped out at 120,000, just got it back it is so nice totally different car.
Old Aug 10, 2004 | 12:22 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
my 86 has the same trans and it shifts in to OD at about 45-50 mph
depending on how hard im pushing it.I can't say with out driving it but i would say its ok.I would check the adjustment in the TV cable.If its to tight it woun't shift.I decided to rebuild it while the engine is out,the guy building it said it was fine for 160K.
To Transmission help.
