quick question.( engine )
Old Aug 9, 2004 | 10:27 PM
whfla's Avatar
whfla
Default quick question.( engine )
i seem to be getting a puff of white smoke at cold start ....and i hear what sounds to be a bottom knock ? any ideas from anyone would be a help ! thanxs ...84 auto .....
Old Aug 9, 2004 | 10:30 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
White smoke is water. gray/blue smoke is oil and black smoke is to much fuel.
Does it run fine?
If so and it's only at start up, I would not worry about it.
Keep an eye on coolant and oil levels.
Old Aug 9, 2004 | 10:36 PM
fastd's Avatar
fastd
Could be just a little condensation in your exhaust.
corvetteronw's Avatar
corvetteronw
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Are you sure it is white? Even though my 87 only has 42,000 on it I had to replace the valve seals. They were very dried out and cracked as I removed them. This caused an embarassing discharge of smoke upon startup after it had set for a while.
Good luck!
Old Aug 9, 2004 | 10:49 PM
ZRWON's Avatar
ZRWON
If you use 5W or 10W - 20 or 30W oil switch to 30 or 40 weight, esp if your car has >75 K miles. That'll help with the knock sound when cold and if it's blue smoke, not condensation, it'll slow oil seepage around "O" rings when not in use. I don't think there's any advantage to using multi grade oils in higher mileage cars, especially in warmer climates such as Fla. Bill
Old Aug 9, 2004 | 11:09 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
OK!
Old Aug 10, 2004 | 12:20 AM
comp's Avatar
comp
you need to make sure of the color
Old Aug 10, 2004 | 01:05 AM
mikey whipreck's Avatar
mikey whipreck
If i were you i would try and pinpoint that knocking noise...
To quick question.( engine )
