88 Cigarette Lighter replacement
Old Aug 10, 2004 | 03:27 PM
DSSKing's Avatar
DSSKing
Default 88 Cigarette Lighter replacement
Just realized that my cigarette lighter doesn't work......had the car for a year, don't smoke, but would like to plug in my GTECH PRO.....
can't. Can't find a replacement ANYWHERE.....Mid-America, nor Ecklers.....
Anyone? Simple replacement, I am guessing....take the console
apart and hook a power and ground.......????
Where can I find one??
DSSKing
Old Aug 10, 2004 | 07:58 PM
vettebldr1's Avatar
vettebldr1
I have a cigarette lighter I pulled out of one of my parts cars, but I don't have the housing, so that probably won't help much, but I believe there is a fuse that controls just the cigarette lighter (maybe something else too, not sure) make sure you don't have a blown fuse. 9 times out of 10 that will fix the problem.
Old Aug 10, 2004 | 11:34 PM
Wayne88's Avatar
Wayne88
You should always look on Ebay for that kind of stuff.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Also, it might not be the lighter.
If I recall right, when I installed my new console plate, there is a connection under the console plate to the lighter. If that is not making contact the lighter won't work.
Old Aug 12, 2004 | 02:05 AM
vettebldr1's Avatar
vettebldr1
That's another thing to check before you replace the one you got.
Old Aug 12, 2004 | 02:18 PM
aj1988's Avatar
aj1988
I got one from O'reilly and it works fine. I did discover there is a fuse (Blue I think) that controls the lighter and the interior lights. So, if you lights come on when you open the door, it is not the fuse.
Since you are going to have the console off anyway, why don't you replace the bulb for your shifter. I also used an orange paint and did the shift indicator (faded) when I had mine off. Sure looks good now.
Old Aug 12, 2004 | 02:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yep you will need to pull the console top to access the cig lighter.
If needed, you may be able to get one at Contemporary Corvette; don't try one of the "universals".
Old Aug 12, 2004 | 03:21 PM
Jim Sitton's Avatar
Jim Sitton
You can buy replacement lighter shells at just about any good auto parts store. I installed one in the console box in my 85 to charge my cell phone. That way I don't have to leave the cupholder door open all the time. I just tapped into the circuit for the console box light. Piece of cake.
Old Aug 12, 2004 | 03:26 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Those things are pretty tough. I'd check the fuse and make sure wires are hooked up before I bought another one.
Old Aug 12, 2004 | 07:51 PM
Muffin's Avatar
Muffin
You have mail.
Old Aug 14, 2004 | 02:12 AM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Walmart. I bought a generic replacement for $4. Installed it and it fit and works fine.
To 88 Cigarette Lighter replacement
