I have an 86 Automatic with gear option GU-2 and want to change to 3.73 gears. I have been told:
1) they no longer make these gears for an 86
2) they are available but make alot of noise
Evidently it is difficult to find this set for such an Automatic with the Overdrive feature.
Where can I find a set of 3.73 gears that will work?
mike
If you do a search on l98 gear swaps you will find most say the 3.07's are the perfect match for an l98. Just thought I would bring that to your attention before your're set on the 3.73's.
...Like Wildman said, unless the engine is heavily modified, 3.07's are a better choice.
Which means you'll probably have to swap a 3 series Dana 36 with the 3.07s already in it for your 2 series diff because I don't believe anybody makes 3.07s for a 2 series carrier. Actually, that's probably a good thing as it's something you could potentially do yourself. There's a Tech Tip on swapping in a Dana 44 rear but the R&R is the same....
