Back Hatch problems
Old Aug 12, 2004 | 09:01 AM
Pioneer's Avatar
Pioneer
Default Back Hatch problems
The only problem that I experience with my 94 is "popping" the back hatch. Some days it will open, but it will not in most cases, either with the remote or the door control.
Is there a manual release or am I stuck with an electrical problem?
Thanks for any help you can provide!
Old Aug 12, 2004 | 09:43 AM
F1Fan's Avatar
F1Fan
Here's my .02. If it doesn't 'pop' itself out of the lock, then it's a spring in the latch assembly you likely need to replace. If it does pop up from the latch, but just sits back down on it, your hatch struts are worn out.
Edit: Hmmm, not sure I've answered the question you asked...
Is the main problem that the latch is just not releasing?
fwiw, I'm not aware of a manual release for it. Do some snooping around for loose/damaged wiring there.
Old Aug 12, 2004 | 10:22 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
There is a manual release for the hatch. Feel around the luggage shade for a thin wire, I think it's near the drivers side of the car. Take a look in the manual to be sure though.
In general, you are looking at some sort of electrical problem. Could be the solenoid but the way you are describing it, it could be anything.
BTW, the manual release is in case the solenoid completely stops working, you can still open the hatch.
Old Aug 12, 2004 | 11:15 AM
Pioneer's Avatar
Pioneer
Default Thanks
I appreciate the info about the manual release.
To the first reply, I probably wasn't very clear on the problem. There is no "pop" at all when I try to activate either the remote or door control.
What seems to be odd is the fact that it works part of the time. The same for the auto door lock. At times, when parked in various locations, it works better than other times.
Who knew?
Old Aug 12, 2004 | 11:51 PM
vettebldr1's Avatar
vettebldr1
I agree about the manual release, it's a cable that is probably hiding under the rear deck trim. As for the 'popping' problem, or not popping I should say. You most likely have a short somewhere, or a bad ground; start looking in your door since the rest of the car is fiberglass. You probably have condensation build up somewhere. Try that and let me know if it helps.
Old Aug 13, 2004 | 04:40 AM
Midnite 88's Avatar
Midnite 88
My hatch release did the same thing for about a month. (I have to get in the hatch area at least 2X a day.) The solenoid finally went completely out. I found a used one on e-bay for ~$20.00. So far I have had good luck with the used one.
BTW: '84-96 all use the same solenoid.
Mike.
Old Aug 13, 2004 | 07:14 AM
Casper's Avatar
Casper
Are you on level ground when it does work?
Old Aug 13, 2004 | 09:51 PM
mikey whipreck's Avatar
mikey whipreck
in my 85, the manual release cable is right below the handle for the shade... It's a cable about 3 or 4 inches long. I only found it when i took apart the rear deck trim.
To Back Hatch problems
