Oil Dip Stick
Old Aug 12, 2004 | 05:00 PM
vetbil's Avatar
vetbil
5th Gear
Default Oil Dip Stick
Anyone ever had the dip stick push out of the sleve. H appened to me the other day and some oil sprayed on the engine causing some smoke. Happened after I got a bit to heavy with the foot. Any thoughts?
Old Aug 12, 2004 | 05:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Perhaps someone had it out and neglected to apply the sealant/adhesive around the base before inserting it.
You can get the sealant at your GM dealer.
Old Aug 12, 2004 | 05:54 PM
ZRWON's Avatar
ZRWON
SEEMS TO ME THAT IF THE DIP STICK BLOWS OUT OF THE METAL TUBE IT RESTS IN THEN THERE MUST BE A BUILD UP OF A LOT OF PRESSURE IN THE OIL PAN?? BLOWBY OF WORN RINGS INTO THE OIL PAN? (sorry about caps) Notice any great loss of compression, excess oil consumption, etc? I've heard of this with in really old tired motors where the dip stick is blown up slightly from the tube and the oil is also blown out of the crankcase onto the motor area. How about breather filters condition? Good luck. Bill
Old Aug 12, 2004 | 06:13 PM
RED-85-Z51's Avatar
RED-85-Z51
May want to check your PCV valve operation, and also check oil level.
What is your Oil pressure at Idle, and High idle?
Old Aug 12, 2004 | 06:41 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I agree, if you're lucky and what ZRWON said if you're not! Assuming the stick still fits with proper snugness (is that a word?) you have excessive crankcase pressure for one or the other reasons....
To Oil Dip Stick
