C4 fuel tank
Old Aug 13, 2004 | 04:35 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
Default C4 fuel tank
How much fuel does a C4 tank hold
Old Aug 13, 2004 | 05:10 PM
myblue91's Avatar
myblue91
Speaking for my 91 it's 20 gals.
Old Aug 13, 2004 | 05:15 PM
Muffin's Avatar
Muffin
85 is 20 gals. Good guess that all C4s are the same.
Old Aug 13, 2004 | 05:17 PM
Perfusion's Avatar
Perfusion
Yup - 20...
Old Aug 13, 2004 | 07:53 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
Wow thats gona be a $40 fill up .The price we pay for the thing we love.I really miss the days of $1.15 a gallon.
Old Aug 13, 2004 | 08:23 PM
ZRWON's Avatar
ZRWON
Me too @ $1.15/gal, but look at the good side; if you fill up every time it reaches the 1/2 mark it only costs you $20 for a fill-up and I get 25mpg now vs 7mpg when I paid about a buck/gal.
Old Aug 13, 2004 | 10:36 PM
96GS#007's Avatar
96GS#007
FWIW, the ZR1 tank was modified to hold less than 20 in 1993. To remain in the same EPA certification class GM had reduce the weight of the '93 ZR1 by a small amount. They did this by installing a rubber extension on the fuel filler pipe to limit the fuel capacity to 18 gallons.
Old Aug 14, 2004 | 08:22 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It holds 20, but you can only use 18 of them. I've run out of gas with 2 gallons still in my tank.
Old Aug 14, 2004 | 09:19 PM
Dominicorvette's Avatar
Dominicorvette
You guys in the US are soooo lucky! Out here in Europe, gasoline doesn't cost 2 dollars a gallon... after having converted liters to gallons and euros to dollars, it costs 7.17 dollars per gallon at the moment.
Dominic
Old Aug 15, 2004 | 12:38 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Interesting... I've filled mine with 19.75 gallons once after sputtering into the gas station when my sending unit broke. There was still enough gas getting picked up to let the car idle but it was difficult to actually drive it.
Old Aug 20, 2004 | 01:14 AM
CentralCoaster
You're the first one I've heard of that's been able to put more than 18 and change in the tank.
Old Aug 20, 2004 | 01:43 AM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
Dominic
what's your minimum wage over there? and taxes on the gas?
Old Aug 20, 2004 | 01:46 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I suppose that the pump could have been off but I hope not by that much. I didn't usually go there for gas so I am not sure.
I got pretty lucky since the car started dying only about a half mile from the station (the only one for about 20 miles).
Old Aug 20, 2004 | 01:48 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Originally Posted by Perfusion
Yup - 20...
Old Aug 20, 2004 | 07:58 AM
runner140*'s Avatar
runner140*
Default How much?
My 1996 holds 29 gal.
Old Aug 22, 2004 | 07:53 AM
Dominicorvette
I had to look that up for you. Minimum wage, for people of 23 years of age and over, is 12168 euros a year, which is about $18k before taxes. Tax rate on income at that level I'm not sure, probably about 20-30%. When you get over a certain amount, say $40k a year, taxrate will be over 50, in some cases even 70%.
The tax on gas is 67 cents per liter. (which costs about $1.28) So about half the price of gas goes directly to the government.
Old Aug 22, 2004 | 02:11 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
How's this?
To C4 fuel tank
Old Aug 22, 2004 | 02:41 PM
CanadaVette's Avatar
CanadaVette
Up here in Montreal I pay 1 dollar a liter.
Just put in 65 liters this morning.
Just put out $65 this morning.
The math is pretty easy.
Old Aug 22, 2004 | 04:50 PM
Dominicorvette
Can I come live with you for a while..? ;-)
Old Aug 22, 2004 | 09:43 PM
4thC4at60's Avatar
4thC4at60
I well remember $100 fill ups when living in Italy.
I've put in 19++ many times over the years in C4s, and run out twice, once in my '91, once in my '94.
