Changing out Front Shocks
So even though the front Bilsteins arent leaking....they are filthy ...the rubber tops are cracking and I'm figuring it cant be all that good to have a mismatched set of shocks.
This is the first time I am doing this ...I have the Hayes manual....and the removal and installation seems pretty straight foward and easy......this of course is what worries me....its never easy!!!!
So before I start the job...does anyone have any suggestions..comments, recommendations or heads-up to look out for .
I checked the linkages and wheels for play all seems pretty tight . There is a clunking noise I hear occassionally from the front end and I am hoping the new shocks will take care of that. Wish me luck !!!
Having said that, this is a pretty straight forward job, & should be pretty easy.
Yeah...I'm an armchair mechanic too!!!!But my chair hasn't any arms!!!!!
Ok thanks all, the clunkinghappens occasionally when I go over a dip or bump... but only a single clunk particularly when turning...doesn't happen alot though...so I'm not too worried
The bilsteins can be a little tricky to change out. They're gas charged, so you'll have to compress it by hand to get it out. The hardest part is getting the upper nut off. You need a tight grip on the upper end of the shock shaft (it's squared off up top to accept a small metric (6mm?) wrench. Soak those top nuts bigtime with penetrating fluid right now, so they'll be easier to remove. That's pretty much all there is to it.
And lube up your bushings while you're in there.
