Remote Keyless Entry
Old Aug 18, 2004 | 12:43 AM
93rubyredvette's Avatar
93rubyredvette
Default Remote Keyless Entry
I have a 93 Ruby with keyless entry and PKE. Ever since I got the car 3yrs ago the keyless entry doesnt seem to work right. The PKE works fine, but if I disable the PKE and push the door button to unlock only the passenger door unlocks. I have to then use the key to unlock the drivers door. PKE enabled unlocks both doors no problem. Anyone know what is up with this?
Old Aug 18, 2004 | 07:40 AM
seawolf's Avatar
seawolf
My 94 does the same thing. PITA. Hope someone has a fix or suggestion.
Old Aug 18, 2004 | 09:15 AM
MinnesotaWhite's Avatar
MinnesotaWhite
I haven't looked for a long time, but I seem to remember from the owners manual you can program that thing to basically lock/unlock whatever you want at the push of a button.
So...someone who didn't know what they were doing or had strange needs for a remote programmed it wrong...and you inherited it.
Do you have an owners manual?
Old Aug 18, 2004 | 10:01 AM
boulderlt4's Avatar
boulderlt4
I've had my '96 since new.
From the dealership, that POS never worked right. I've never been able to unlock anything BUT the passenger door with my remote.
Old Aug 18, 2004 | 10:10 AM
1Patriot's Avatar
1Patriot
If you read the documentation then you would discover that the PKE when activated will unlock both doors as you approach the car or lock both doors when get get about 10 or so feet away from the car.
When the PKE is active, the door button on the fob affects the passenger door only and the passive function controls both doors.
To deactivate the passive function, open the drivers door and hold down both door buttons until the solenoid clicks twice. To change the state of the PKE repeat the procedure.
Old Aug 18, 2004 | 10:46 AM
Red Dwarf's Avatar
Red Dwarf
If you want to select which door/s the PKE opens when you approach the car, put the key in the ignition, donot turn "on". Hold down the door button on the folb until you get the desired results. With PKE inactive it will only open the pass/door & the hatch.
Old Aug 18, 2004 | 11:06 AM
F1Fan's Avatar
F1Fan
Red Dwarf:
"With PKE inactive it will only open the pass/door & the hatch."
1Patriot:
"...and the passive function controls both doors."
Sounds like both guys are talking about PKE being inactive, one says it only does one door/hatch, the other says it does both door/hatch"
I'm confused. My '95 only does the passenger door and hatch w/pke in passive mode.
I understand how to change which doors are operated w/pke, but can you program the passive mode too?
Old Aug 18, 2004 | 03:02 PM
victoria vette 94's Avatar
victoria vette 94
but can you program the passive mode too?[/QUOTE]
Not that I know of it's frusterating. But you will look like a gentleman if you open her door first, when really your just doing it so that she can unlock yours. hah ah
Old Aug 18, 2004 | 03:42 PM
Red Dwarf's Avatar
Red Dwarf
Originally Posted by F1Fan
Red Dwarf:
1Patriot:
Drivers door/all door unlock option.
The user of the PKE system, will be able to choose whether or not the passenger door unlocks passively. The PKE will always unlock the drivers door during the passive unlock procedure. This procedure can only be accessed from the transmitter in range/key in ignition mode. To enable or disable this feature.....
A valid transmitter must be in range.
The key in the ignition & the ignition is "off".
The door buttton is pushed for longer than 2 seconds.
When this occurs the PKE will lock all doors to confirm to the user that the driver's door only or all doors unlock option has been selected. If the drivers door only option has been selected, the passenger door can be opened by pressing the door button.
Pass door manual unlock procedure.
The PKE system will unlock the pass/door when the flwg conditions are met:
A valid transmitter is in range.
The ignition is "off"
The door buttonis pushed for less than 2 seconds.
Manual hatch release same........Hatch release will disarm UTD if held when coming into range. Whew!!! Sometimes I get my passive & unpassives mixed up...
To Remote Keyless Entry
