radiator replacement
Old Aug 19, 2004 | 04:01 AM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
Default radiator replacement
more than likely going to be replacing the radiator friday, any hints/tips/cautions/etc...? Don't want any surprises being thrown at me (still don't have a repair manual), like when replacing the sun visors, I had no idea they were spring loaded, nearly shot by a car! I have an 87 vert in case you were wondering.
Old Aug 19, 2004 | 05:21 AM
SupaVette's Avatar
SupaVette
It's pretty simple if i remember correctly. You just remove all the large bolts around the top edges of the shroud, the 5 small ones on top and thats it. Lift the shroud off and take the rad out. the only slightly tricky (normally a scratch or 2 on the hand) is the cradle for the a/c filter.
Old Aug 20, 2004 | 01:11 AM
PsychoNumber1
also...
which is the best way to fill the coolant (radiator then overfill, just radiator...?) AND any tricks to bleed the air from the coolant system?
Old Aug 20, 2004 | 01:50 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Replacement! Big time.Yep, one of a kind.
WoW!
Old Aug 20, 2004 | 02:28 AM
PsychoNumber1
also... I live in 100+ heat, should I also use the wett water stuph or anything else?
Old Aug 20, 2004 | 02:51 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
There is a little gizmo that plugs into the R/H tank hooked to a wire. Its the low coolant sensor. IF you can remove it from the old radiator without breaking the clips.... Otherwise don't remove the plug on the new rad until you have a good sensor in your hand. Probably need to mail order one or pay the big bucks at the dealer. I just grounded out the wire and kept the plug in.
-JRC-
So WTF is stuph? Oh! Stuff! How cool to mispell words.......
Old Aug 21, 2004 | 11:11 AM
PsychoNumber1
-JRC-
Unfortunatley the clips did break and I was unable to check the forum YESTERDAY!!!! So, I'm going to see if I can find one. I also lost a hose clamp off the overfill hose, I have no clue where it went, possibly the dry vac from when we were cleaning between the A/C and rad area (lots of pine needles and a partial plastic bag. We did find the hole in radiator too, it was about half way down the l/h plastic tank, there's a crack running along the rib where the water just drained out almost as fast as I could fill it.
As for the misspelling it's a habit I picked up years ago while chatting, besides it's to replaces f's with ph's
Old Aug 21, 2004 | 11:13 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Look at the tech tips(found under "Other" at the top of the page, very good write up by Lars.
Old Aug 21, 2004 | 12:14 PM
PsychoNumber1
Default more
GOOD NEWS! I was looking in the box for a diagram or ANYTHING that could help me, so I'd be sure to know what to call sensor when hunting for a replacement, low and behold I found a new sensor in the bottom of the box! it saved me from going YAY!
To radiator replacement
