Brake problem
Old Aug 19, 2004 | 08:18 AM
alfonso gomez's Avatar
alfonso gomez
Default Brake problem
My 87 Coupe does not have ABS. It was removed some time ago because the replacement was too expensive. I have rebuilt front calipers (from Corvette Central) and OEM pads. The master cylinder is 2 years old, the front discs are 4 years old.
My problem is that when I hit the brakes hard, the front right wheel locks up.
Both front brake hoses are new. Also, when the brakes are hot, the front right pads squeal like a stuck pig.
Before I take anything apart, what may be causig this condition? Wheel bearings?
Thank you.
Old Aug 19, 2004 | 08:26 AM
aklim's Avatar
aklim
Sounds like calipers are hanging up. Clean up the calipers and wire brush any slide pins and use good anti-sieze on them and see if that helps. If not, you probably should replace both front calipers.
