Replacing Lower Ball joint.
Old Aug 24, 2004 | 07:00 PM
Southern Comfort's Avatar
Southern Comfort
Default Replacing Lower Ball joint.
Is $285 bucks too much to replace a lower ball joint and alignment?
Old Aug 24, 2004 | 07:05 PM
bogus's Avatar
bogus
It's not that hard... I did my lowers in a matter of minutes with the right tool.
Old Aug 24, 2004 | 07:48 PM
Southern Comfort
And what would that tool be? I see the one in the shop manual that looks like the same tool for u joints but bigger.
Old Aug 24, 2004 | 08:56 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
A good vette alignment by itself is $150, so it doesn't sound unreasonable. They do know they're doing a 4-wheel corvette alignment right? They've gotta deal with rear toe & rear camber...
Old Aug 25, 2004 | 12:52 AM
ZELLSLIFE's Avatar
ZELLSLIFE
I just had my 95 aligned to VBP specs at a local Chrysler dealer witha new state of the art machine all four wheels for $60.00
Old Aug 25, 2004 | 12:55 AM
ZELLSLIFE's Avatar
ZELLSLIFE
Just to make sure we are talking about the same part the lower ball joint or tie rod end is what you are talking about right if so they are about $39.00 apiece and took us about 30 minutes to install both sides on the front including the greasing the rear uses the same part. It wasn't a hrad job at all.
Old Aug 25, 2004 | 01:30 AM
Frizlefrak's Avatar
Frizlefrak
It's not outrageous, but do it yourself and save $90 for about 2 hours of work.
Ball Joint from Napa = $89
Renting ball joint fork from Auto Zone = Free
Having brake shop press out old ball joint and press in new one = $30
Good 4 wheel alignment from reputable shop = $75
Grand total = $194
Seriously, this is a lot easier than it looks.
Support the car on a jack stand
Place a floor jack under the control arm and lift slightly
Disconnect shock absorber and sway bar.
Remove nut from ball joint, and lower jack slightly.
Insert fork between ball joint and control arm, and smack it with a hammer.
Once it separates, lower the control arm slowly to relieve spring pressure
Remove two bolts that connect to frame, and remove control arm.
Install is reverse, just be sure to torque everthing correctly. Pay yourself $45 an hour in labor.
May as well change the bushings while you have it off.
Old Aug 25, 2004 | 10:21 AM
n1kki6's Avatar
n1kki6
that sounds pretty reasonable, but i would still do it myself. I just did mine it only takes about an hour or less a side.
Old Aug 25, 2004 | 11:30 AM
Vetterin's Avatar
Vetterin
OR....2 ball joints from ebay $59 pair + shipping = $67 total
To Replacing Lower Ball joint.
