Spark Plug Removal - SOL
Advice Please.
Brian
i had a worse time loosening the plug boots off of the plugs, and getting a socket on the plug itself than the plug being stuck in the head.
there were a lot of posts in the archives on LT1 plug changes, but don't know if they are accessible anymore.
let's see if i can highlight some pointers:
- jack up front of car, remove wheels
- remove plastic splash panels for better accessibility
- long ratchet extension and U-joint are essential
- on driver's side, loosen the ASR unit (don't have to remove)
- when installing new plugs, put a THIN coating of antisieze on threads
- coat a little dielectric grease on the inside of the boots before putting them back on
- have a six pack nearby - it might take a while the first time
good luck
http://www.madvet.com/-/shop?frame=1.652
Although I see they are temporarily out right now. Maybe try ecklers.
Advice Please.
Brian
Just did my 94 (that had factory plugs- 10 yrs) anyway, I had no problems that I didn't cause myself! but- thats typical!!
Make sure you put anti-seize back on....as well as that lube that goes in the plug wire boot...will make it nice and easy(ish) in the future...which I hope I don't need to do in MANY years...LT1 plug\wire changes are a PITA!
good luck
Follow the above steps and you will be ok.
Be careful to not tighten the new plugs too tight. The torque spec is 11 ft.-lbs. for the LT1. As mentioned, a slight coating of some anti-sieze to the threads on the plugs and insert them by hand and turn a couple of times to insure the threads have seated properly before tightening down.
The number 6 and 8 plugs are a beotch to do but with a little work, you can get them swapped. Get a plug socket with a hex end on it; you can use a combination wrench to loosen the plugs. A socket and u-joint is next to impossible to use for the #8 plug.
When you remove the plug wire from the plug, be sure to twist the wire boot about a 1/4 turn and then pull on the boot, not the wire.
Definately remove the center plastic fenderwell panel and the rear panel. With these gone, the front 2 plugs on both sides are almost a straight shot with a long extension. Beer does help!!
Ask me how I know.
I was able to get the #3 plug out without any problem, which is probably the same plug I pulled out 5 years ago when I bought the car. I don't need to replace them right now so I'll continue to enjoy the car and make this a winter project.
Thanks Again!!
Brian
I sent off for the Sidewinder close quarters ratchet...nice gadget but in my honest opinion, not necessary. Agreed the #6 and 8 are the worst, but very attainable with an extended handle, flex head ratchet, and most important, a stubby extension, not the 3 inch, the stubby. All in all I used the stubby and the 3 inch with the extended and standard ratchet. Did not remove either of the shields or jack up the car either, didnt find that necessary. Did remove the ASI unit, ok, unbolted it, disconnected the hoses and laid it off to the side...and agreed, use the anti-sieze! I SWEAR they were the original plugs in my 120K Vette, and they still had the Anti-sieze on them and came out with no worries.
Now the replacing the wires....
If in NEVER have to do that again, it will be too soon!
G-Luck
