Sagging headliner
Old Aug 25, 2004 | 12:32 AM
metjoy's Avatar
metjoy
Cruising
Default Sagging headliner
We are the delighted new owners of a 1987 coupe with two tops. We put the solid top on for the first time and by the end of the ride, the headliner was seriously messing up my hair. Has anyone out there repaired their own headliner? It doesn't seem really straightforward how to remove the frame around the headliner to re-glue it. Is this a job better left to the pro's? I have headliner glue and some experience in upholstery. Thank you!
Old Aug 25, 2004 | 01:11 AM
LaTechEE's Avatar
LaTechEE
I redid mine a couple months ago because it was sagging. I just removed the center part which is pretty cardboard or something covered with fabric. After I removed I took it to car upholstry place in town and they recovered it for 20 bucks and it looks better than new. I had to pry it out with a screwdriver or something dont really remember. Anyway, just make sure you keep the thing the fabric is attached to intact and you can get it recovered really cheap. I reattached it with some double sided tape and velcro pads.
Old Aug 25, 2004 | 07:01 AM
comp's Avatar
comp
sounds like a fix
Old Aug 25, 2004 | 08:19 AM
vettefast's Avatar
vettefast
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Aug 25, 2004 | 09:40 AM
EPiC Vette's Avatar
EPiC Vette
I used a local upholstry shop for mine. Took in the top, saggy headliner and all. Cost me $150 and two days of topless Cali sunshine !
Worth it to me.
Old Aug 25, 2004 | 10:46 AM
Red Dwarf's Avatar
Red Dwarf
I can e-mail you an article from Vette magazine with info on liner replacement or you can go to vettemagazine.com (I think) for the information?
Old Aug 25, 2004 | 11:37 AM
metjoy's Avatar
metjoy
Cruising
Default Thank you!
Thanks to all who responded! This forum is the greatest!
Red Dwarf, could you please email me the directions?
God Bless,
Metjoy
Old Aug 25, 2004 | 11:51 AM
yellowlust's Avatar
yellowlust
See sig for best cure for sagging headliner...
Old Aug 25, 2004 | 08:08 PM
metjoy's Avatar
metjoy
Cruising
Default need decoder ring
OK, I'm a newbie here, and need the official decoder ring. I'll check out the sig as soon as you tell me what that is....
:o
Old Aug 25, 2004 | 08:11 PM
6spd 1990 Cpe's Avatar
6spd 1990 Cpe
Got my material from this guy on e-bay (Good Stuff), my headliner spray glue from AutoZone and did it myself. Figured if I screwed it up It didn't cost much anyways to do again. Especially after I was quoted around $150 from a few trim shops in the area to do it. Not a hard job at all. Just takes patience & the willingness to drive around without a top on for a day or 2 !!!
<<--- Hey where'd the other wavin' lil guy go ??
Old Aug 26, 2004 | 01:02 AM
gleninsandiego's Avatar
gleninsandiego
The sig is the signature line at the bottom of the post. When it was first posted the sig had a picture of a convertible, but I am not seeing it now.
Old Aug 26, 2004 | 10:44 AM
Red Dwarf's Avatar
Red Dwarf
God Bless,
Metjoy
Need your e-mail address.........................
Old Aug 26, 2004 | 08:06 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
I fixed mine for about $7. Get a big piece of felt. I used red instead of black. Pull the old stuff off, and pick any pieces of loose stuff off. lay the felt down and trim it with a exacto knife, but leave some extra on the sides. Don't trim it close or you will leave gaps. Take a can of Elmers Craft Bond Spray adhesive and spray the area well. lay the felt down and stretch it out well making sure there are no wrinkles and smooth it out with your hand or a credit card. Instead of trimming it around the edges it is better if you use the back end of the razor to tuck it in on the edges rather than cutting it, so you don't have any gaps. It cost about $4 for the felt and $3 for the adhesive. If you use black it will look like the original headliner. I used a bright red that matched the paint.
I have pics but don't know how to post them
Old Aug 26, 2004 | 08:15 PM
CREWZIN's Avatar
CREWZIN
Check around for prices if you deceide to have it done professionally. Got mine recovered for $80
To Sagging headliner
