Tire Shine?
Old Aug 27, 2004 | 12:33 PM
Darth Vader's Avatar
Darth Vader
Default Tire Shine?
My 96 original tires 12k look a little dull. Does the Tire Shine products cause cracking of the tires? Ive heard that Armor All is bad. So I was thinking of the Black Magic Tire Shine. Any thoughts? Do most of you use tire shine or just leave natural?
Old Aug 27, 2004 | 12:43 PM
n1kki6's Avatar
n1kki6
get meguires
Old Aug 27, 2004 | 12:44 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
I have used the Tire Magic jsut do not over do it . I wipe off all the excess when I do use it , but the best tire dressing is Meguirers ....
Old Aug 27, 2004 | 12:46 PM
Jet-Jock's Avatar
Jet-Jock
I don't I just wash them with the wheels. I'm sure folks will have lots of opinions on this. One thing to consider is black carbon is added to the rubber compound to make them black and to prevent deterioration from ultraviolet radiation. Some products contain chemicals or silicone which damage that an accelerate the rubber aging. That is what you see with the surface cracking. It is normal for the tire to slightly gray from the deep black color when new. The rubber itself is gray hence the black carbon.
rick lambert's Avatar
rick lambert
Turtle Wax, Wet N Black, I know alot of guys don't like the wet look, but I do. Armour All sucks.
Old Aug 27, 2004 | 01:06 PM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Get Meguire's High Endurance (liquid) or Stoner's Trim and Shine areosol. They're DOPE!
Old Aug 27, 2004 | 02:00 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
Old Aug 27, 2004 | 02:46 PM
Red90Coupe's Avatar
Red90Coupe
Zaino has a very good tire care product. Go to www.zainobros.com to research.
Old Aug 27, 2004 | 07:30 PM
F1Fan's Avatar
F1Fan
The only tire 'gloss' I've ever used that I thought was worth a crap was Zaino's. Everything else is too glossy IMO, and I don't think tires look good being glossy. And yes, Armor all is garbage. Way too glossy and greasy looking on anything you put it on. And it used to (and probably still does) contain alcohol, which will dry up and crack your surfaces unless you keep it perpetually drenched in it..
Old Aug 27, 2004 | 08:48 PM
rubyred93's Avatar
rubyred93
Vinylex
Old Aug 27, 2004 | 09:58 PM
scofolo's Avatar
scofolo
I've been using black magic for 2 years now with no problems
Old Aug 27, 2004 | 10:00 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Originally Posted by n1kki6
get meguires
Old Aug 27, 2004 | 10:40 PM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
I like Turtle WAx Tire Wax
Old Aug 28, 2004 | 12:01 AM
skybolt31's Avatar
skybolt31
Default Shoe Polish is best
I use Kiwi black, little more work, but can be spiffied up with a shoe brush now and then and lasts for months
Old Aug 28, 2004 | 02:13 AM
nick418's Avatar
nick418
Cruising
I use Black Magic Tire wet Gel. I hate the sprays it gets all over the car and everything. I like to use the GEL
Old Aug 28, 2004 | 07:09 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I hate the glossy look, so for the past 4 or 5 years have been using STP Son of a Gun on all my tires (four cars). It gives that perfectly flat black look of a brand new tire and it lasts for months. Never had a weather-checking problem with the stuff either.
Larry
code5coupe
Old Aug 28, 2004 | 10:24 AM
~SlvrFox~'s Avatar
~SlvrFox~
St. Jude Donor '05
I've been using Black Magic and applying it with a sponge to achieve a satin finish and it definitely enhances the appearance while not being too "glossy."
Old Aug 28, 2004 | 10:37 AM
rbesq's Avatar
rbesq
It looks like I'm in the minority, I don't think the car looks truly clean without the wet look on the tires. I use Turtle Wax spray.
Old Aug 28, 2004 | 05:45 PM
Steel Blue 91's Avatar
Steel Blue 91
I like AP 303. Low gloss and lasts a good while.
To Tire Shine?
