Manual Trans Fluid Change
Old Sep 2, 2004 | 04:23 PM
Texas White 93's Avatar
Texas White 93
Default Manual Trans Fluid Change
Will three bottles of the BMW Oil 10W60 be enough to change the fluid in my 6 Speed. I just noticed that each one is a 1L.
Old Sep 2, 2004 | 04:31 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
If my memory serves correctly, it takes 2.2l. Just keep pumping it in until it starts leaking out the fill hole....
Larry
Old Sep 2, 2004 | 05:20 PM
swifty's Avatar
swifty
Check with "ZFDOC" (or similar) on this forum about your tranny fluid. One of the guys in our local (Spokane) club drove to his state (?) for a 6-speed rebuild then reported on his experience. First Rate!
He also said to only put 2 bottles of fluid in - not 2.2 - because it gave a little room for expansion. That's second-hand information, not first-hand, but you should be able to find out here on the forum.
I'm getting ready to do mine now, and am going with the 2.0 advice.
Old Sep 2, 2004 | 05:28 PM
TD-Machines's Avatar
TD-Machines
BMW Oil 10W60. Is this motor oil?
Old Sep 2, 2004 | 06:21 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
It's 2.2 quarts capacity for the zf6.
Yes, will will need to get three bottles.
Yes, it is engine oil.
Old Sep 2, 2004 | 06:36 PM
tempest's Avatar
tempest
i just kept pumping it in until i got a steady stream coming out of the filler hole. took a bit more than two bottles.
Old Sep 2, 2004 | 07:56 PM
LD85's Avatar
LD85
I used 2 bottles and a little
Old Sep 2, 2004 | 10:56 PM
bogus's Avatar
bogus
There is a ton of room in there for expansion. Think about it, when you fill it, it's only about 1/2 the case. And there is a vent tube for pressure to release from.
The capacity is 2.2 QUARTS. The annoying part is that 1 litre = 1.05 quarts, hence, 2 litres is 2.1 quarts. argh.
And when it is filled, make sure the car is level. Otherwise, you might underfill it.
Old Sep 3, 2004 | 06:16 PM
Perfusion's Avatar
Perfusion
ZFDOC is in Phoenix, AZ
To Manual Trans Fluid Change
