Headlight Dimmer Switch
Old Sep 6, 2004 | 10:24 PM
Texas White 93's Avatar
Texas White 93
Default Headlight Dimmer Switch
Hi, has anybody replaced a Dimmer Switch? My headlights will only work on low beam. When you pull or push the lever there is no click and nothing happens. Do you have to remove the steering wheel to replace this switch?
Old Sep 7, 2004 | 08:29 AM
Texas White 93
Default Dimmer Switch
Need to fix this problem as soon as possible as where I live there are so many Deer out I am afraid to drive after dark with out the use of high beams. Any Idea's
