I can get to it from coretteforum.com main page, it's under tools. But last week, I couldn't. I think they must have fixed this problem. This is with the 'old' menu and home page though, like it used to be. Are you seeing the old menu, or the newer one?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, that works. But I had been accessing it from the tool bar since the software change. It is still not working. I just recently got the "old" home page back, which I like better. I started getting the new one after the crash but now the old one's back. Thanks!
I'm seeing the same problem none of the tool bar menus work now, you click they fold down then when you drag the mouse down they hop all over the place.
Opps, they must have just fixed it now they work again. Never mind.
I get can there from here no problem and havent had a problem doing so during the whole software and server probs. I just go to top of page and click "other" and then "tech tips" then choose what "C" I'm after (which is always C4?) I was recently glad to see that the tip I submitted in June on bench testing fan and other relays and wiring a manual fan switch was finnally there. https://www.corvetteforum.com/techti...=282&TopicID=2
It's kind of compressed but it's there. I was surpised to see they had time for this during all the other recent troubles with the site.
THREE CHEERS FOR TROY!!!
Yep Troy & company learned a lesson too, for 99.9999% continous operations you need a dual controller RAID system with fail-over and fail-back, and RAID doesn't mean protection, you must have daily backups.
