FX3 Conversion
Old Sep 17, 2004 | 10:26 AM
shribe's Avatar
shribe
Default FX3 Conversion
I have a 92 with a busted FX3 system. Would it work to put on 91 shocks with a 91 control module? I know the problem was a 92 up shock valve only rotated 90 degrees, but if you changed the controller, it should work, right?
Old Sep 17, 2004 | 03:28 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Yes, if you change out the controller, it will work.
Old Sep 17, 2004 | 03:49 PM
ClarenceT's Avatar
ClarenceT
is one more reliable/desireable then the other? Mine is busted too :-/
Old Sep 17, 2004 | 03:54 PM
Jeffvette's Avatar
Jeffvette
the later model hasa 90 degree movement, whereas the early models had 16-180 degrees of rotation. Cuts adjustment time down..... whoopty doo.
Old Sep 17, 2004 | 04:15 PM
ClarenceT's Avatar
ClarenceT
Is that all? hahaha, wow. I figured they redesigned it to be stronger and hold up better.. silly me.. Oh well;
Old Sep 17, 2004 | 11:27 PM
shribe's Avatar
shribe
Thanks Jeffvette, that made my day.
ClarenceT, I sent you an email, I located some extra parts.
To FX3 Conversion
