Computer question
Old Sep 19, 2004 | 12:34 PM
Fick's Avatar
Fick
Default Computer question
I've heard that the cars computer will adjust itself to the way the car is driven. What does this mean? How does it affect the way the car drives and performs? Does the computer adjust itself continually with changing driving habits? Will the car run better if it's driven more aggressively?
Old Sep 19, 2004 | 12:45 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Good question. I have always wondered the same thing. If this is the case, what year did this start? I know they changed the computer from OBDI to OBDII in 96 (me thinks).
Old Sep 19, 2004 | 01:54 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Yep 96 has and OBD II. I have heard the same thing and if you disconnect the battery then the PCM takes a few miles to relearn everything.
Old Sep 19, 2004 | 02:49 PM
Fick's Avatar
Fick
Thanks for the replys; but I'm still wondering how the computer adjusts. It can't adjust shift points with a manual and red line is not changed. How is the drivability of the car influenced? Anything specific?
Old Sep 19, 2004 | 02:56 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Some cars have that feature, although I don't believe that the C4 Corvette's computer does this. I think this has to do more with electronic transmisions in cars that have this ability. They adjust shift points depending how you drive it. If you lay into the throttle alot it will give you a more aggressive type of shifting. Then throw in the speed sensitive steering, and you have an automobile that drives to your style.
Old Sep 19, 2004 | 02:58 PM
scorp508's Avatar
scorp508
To a degree the car can learn how to alter air/fuel mixtures for optimal performance at full and partial throttle positions.
Old Sep 19, 2004 | 05:00 PM
mitymek's Avatar
mitymek
far as i know it doesnt really learn "you" so to speak.
what its doing is calibrating sensor input and adjusting air/fuel ratio and timing to the optimum after a reset.
i usually go out and run on em pretty hard during that initial "learn" just so it doesnt have to do it at a later time,possibly during a critical mustang pass.
obd 1 cars do this also,only difference is obd ll has a lot more parameters it deals with versus obd 1.
good question.and i dont want to come off sounding like an expert by any means.this is just the way i THINK it works,judging by the data accessible to our monitor 4000 at work when plugging in to obd1 and obdll vehicles.
Old Sep 19, 2004 | 05:38 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Here's something that has helped me understand more about how ECM/PCMs work. It MUST be fairly well written if I got something out of it!
http://para.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
Old Sep 19, 2004 | 07:51 PM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
This is precisely why you need to vary your speeds wwell after your motor has been "broken in". Same thing goes for Porsches. The ECMs in our vettes regulate just about everything in the car and I'm sure they adjust to how the car's driven. If you drive like an 82 year old woman 98 percent of the time and floor it like a bat outta h e l l 2 percent of the time, your engine and everything else your vette's comprised of isn't gonna laste very long.
Old Sep 19, 2004 | 08:01 PM
mitymek's Avatar
mitymek
if you took a poll i bet you would find that thats exactly how 95% of us drive our vettes.
Old Sep 19, 2004 | 11:07 PM
Draven's Avatar
Draven
St. Jude Donor '14
I'm the opposite.. Only I don't speed (often). I just get UP to speed QUICKLY. ; )
-Joe
Old Sep 19, 2004 | 11:49 PM
tempest's Avatar
tempest
largely categorized there are two types of learning algorithms - those that learn differences in the car itself, and those that learn the driver "style" or driving conditions.
examples of the former include BLM's and initial IAC valve position. it makes (usually) small adjustments to take into account for some variance in the vehicle or sensor/actuators. these algorithms can, however, be affected by how the vehicle is driven, but that is usually not the intent. this type of a learn algorithm has been around pretty much since ECM's have been around.
the latter has appeared only in the last few years or so. it checks to see driving habits (ex. pedal position history depending on driving conditions) to adjust the amount of torque the engine or transmission generates. the only application with which i am familiar is with tranny controllers. if the driver is aggressive, the TCM can adjust shift lines to a higher RPM. i'm certain there are analogous algorithms out there that apply to ABS, engine control, and chassis (stability) control.
To Computer question
