short?
Old Sep 22, 2004 | 04:49 PM
Hippiehead025's Avatar
Hippiehead025
Default short?
i was driving this morning, and all of a sudden my dash lights went out, and back on multiple times, aswell as the SES and S ABS light.....my motor was sputtering, but then after 5 seconds it was fine? any ideas?
Old Sep 22, 2004 | 05:00 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Nothing worse than an intermittant electrical problem....nothing!
Larry
Old Sep 22, 2004 | 05:15 PM
Hippiehead025
Larry
does any1 make those imroved wiring harnesses for my car yet? (90 L98) I checked painless but they say you need a specific number ECM. and i have the number, but dont know where to find it...... 1227730 is the number.
Old Sep 22, 2004 | 05:52 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Sounds like an intermittent open or poor connection somewhere. Check your battery terminals for corrosion and the cables for tightness. Also, if you have a volt meter, measure across the battery when running and not running. You should see about 12.5 volts when not running and about 13.5 to 14 when runnning. Other than that check all connections at your computer and any that you can see for tightness and corrosion.
Old Sep 22, 2004 | 08:16 PM
Hippiehead025
did all tht already, haha my terminals rnt the tightest, b/c one is kinda stripped...... so i thaught it was tht, but my radio was playin real loud, nvr even flinched, but the dash and engine and **** went flicked for a couple seconds....weird.....
Old Sep 23, 2004 | 09:35 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
????????? Beats the Hell outta me.?????????????
Old Sep 23, 2004 | 10:03 PM
Wheelman's Avatar
Wheelman
If youre asking.....yes....1227730 is the ecm in your '90
Old Sep 23, 2004 | 11:40 PM
Hippiehead025
so the wiring harness will work then....... where did you find this number at? i saw a a few numbers on the ecm, but not tht one....or is tht number onthe bottom or sumthin?
Old Sep 24, 2004 | 01:20 AM
Wheelman's Avatar
Wheelman
I don't know that its on the ecm anywhere I just know the '730 is the ecm used in tpi cars of your year.....Got a little into chip burning / tuning and taught myself a few things
Old Sep 24, 2004 | 03:53 PM
Hippiehead025
sweet, ty, u can help me otu with a custom chip then later this yr....lol
To short?
