Oil Change & Filter Problem
Old Sep 22, 2004 | 11:18 PM
MYBLUEHEAVEN's Avatar
MYBLUEHEAVEN
Default Oil Change & Filter Problem
Recently did my own oil change and per "The Forum" ideas went with Mobil 1 oil and Mobile 1 filter. The problem came when installing the new Mobil 1 filter. It was such a tight fit between the heat shield and oil pan, I couldn't get it tight enough. So, went with a slightly longer, smaller diameter Amsoil SDF-23 so I could get some leverage to tighten it properly. Has anyone else experienced this lack of clearance with the shorter squatty sized filter? Thanks in advance for all you help the last two years.
Old Sep 23, 2004 | 01:58 AM
comp's Avatar
comp
there are some place's i use a wrench to get it snug
Old Sep 23, 2004 | 07:25 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I also use the AC/Delco PF-52's and I've never had a problem with hand tightening them...
Old Sep 23, 2004 | 09:44 AM
Hex04's Avatar
Hex04
I use the same! No Problems!
Old Sep 23, 2004 | 09:49 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Simple solution: get the K&N. It has a handy nut on the bottom.
There are cheap oil filter "sockets" that grip the very bottom of the filter and use a 3/8" drive. They work, too.
Larry
Old Sep 23, 2004 | 09:56 AM
96zride's Avatar
96zride
St. Jude Donor '04 &'05
I use the Napa gold, same as wix.
Old Sep 23, 2004 | 10:25 AM
c4cruiser's Avatar
c4cruiser
I'm using AC-Delco Ultraguard Gold UPF-52 filters I got at the dealer before they quit mking them and they work fine. The standard AC Delco PF-52 or any other brand filter for the LT1 should work fine.
I hand tighten mine by going 3/4 of a turn past where the rubber gasket in the filter contacts the base just like the instructions state and have never had any problems with getting it tight or any leakage. Are you putting a film of oil on the rubber gasket as the instructions state?
To Oil Change & Filter Problem
