Haltech or Accel DFI?
Old Sep 26, 2004 | 08:27 PM
Hippiehead025's Avatar
Hippiehead025
Default Haltech or Accel DFI?
which is better for stand alone fuel management?
Old Sep 27, 2004 | 03:22 PM
RonRed89's Avatar
RonRed89
There are more options than just those 2, but if those were the only 2 choices, I'd pick Accel DFI simply because between the Gen6 DFI and the Gen7, there are lot of installed units out there.
The new Halltech (EG6M I believe) was supposed to be a plug and play unit where you'd remove your old ECM and plug this one in its place. As far as I can see, it's yet to be proven, but does appear to be a good idea. The hot item in terms of programmable ECUs would have to be the Big Stuff 3 (http://www.bigstuff3.com) which adds native 4l60/4L80E control and self-tuning among its list of impressive features. It's also not cheap at all.
What is your current setup? You don't need to step up to one of these units until your setup is fairly radical (low idle vacuum) or when you want wideband O2 tuning.
Ron
