Speaker fitment question?
Old Sep 29, 2004 | 04:36 PM
da6speed's Avatar
da6speed
Default Speaker fitment question?
Will a 6.5" speaker fit in replacement of the front speakers on the 90-96 models that have the front speaker below the door in the sill area? TIA
Old Sep 29, 2004 | 06:25 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
I'm not sure? See if Crutchfield can shed some light on the subject for you. They may have a replacement guide.
Chris
Old Sep 29, 2004 | 07:10 PM
aeronautica86's Avatar
aeronautica86
crutchfield won't tell you anything
Old Sep 29, 2004 | 08:35 PM
tempest's Avatar
tempest
i've got 5.25" up front with modified Bose enclosures and there is some room for a bigger speaker if custom enclosures are used. however, i don't think anything above 6" will fit.
Old Sep 30, 2004 | 12:53 AM
bogus's Avatar
bogus
A 6" WILL fit... you just have to build the enclosures to make it fit!
I did... and I will try to post the instructions in Audio tomorrow.
da6speed's Avatar
da6speed
Well....what size speaker is everyone using for the front speaker replacement?? Trying to order some speakers asap so I can have them in by 8/6/04. TIA
Old Sep 30, 2004 | 12:56 AM
bogus's Avatar
bogus
that was 2 months ago???? Or are you that far behind???
Old Sep 30, 2004 | 01:31 AM
da6speed's Avatar
da6speed
It has been a long day I meant Oct. 6, I guess that would be 10/6/04.
Old Sep 30, 2004 | 01:46 AM
bogus's Avatar
bogus
ah, cool... my brothers birthday!
however, I will post pics and dementions tomorrow.
I have a set of Boston Z6 speakers in there... I need to finish the install, so this is as good a reason as any to pull'm and do it to it!
Old Sep 30, 2004 | 02:41 AM
Draven's Avatar
Draven
St. Jude Donor '14
I put a set of component CDTs up front, with 6 1/2 drivers... You need to custom build an enclosure... I was on a time budget (can't be without the car for any larger given amount of time), so I cut into the pastic and literally mounted them to the plastic under the carpet. They barely fit that way, but it works. One of these days, I'll get more ambitious and build something to sit behind it for added support, but for now, it works.
-Joe
Old Sep 30, 2004 | 03:17 AM
black_89_vette's Avatar
black_89_vette
I installed 6.5 " JBL EC 6.2 component speakers. I took out the amp and speaker box and had the guys fit them in. THey used some MPF board and it fit with not cutting of the inner door.
THey also installed JBL GTO936 6 x 9's in the hatch area with no cutting required.
I went with JBL cuz when I was in the BEST BUY store, I listened to Pioneer, Kenwood, Sony, Rockford Fosgate and JBL. I thought the JBL sounded better than any other speaker they had there.
Old Sep 30, 2004 | 05:53 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
the deciding factor will be the depth.
Old Sep 30, 2004 | 09:36 AM
da6speed's Avatar
da6speed
Now you guys got me wondering if 6x9s will fit in the back uner the orig. covers? Thanks for all the info.
Old Sep 30, 2004 | 01:15 PM
bogus's Avatar
bogus
yes.
You have to make a baffle to adapt the 6x9 to the space, but yes, it will fit.
Infact, with some trickery, you can fit 8"s in there!!!
Old Oct 2, 2004 | 05:47 AM
C10 JDR's Avatar
C10 JDR
I have 6 x9 in mine, but I have the covers that came with the speakers, and a plywood baffle.
Old Oct 2, 2004 | 10:05 AM
da6speed's Avatar
da6speed
What are you referring to as a baffle?
Old Oct 3, 2004 | 04:50 PM
LD85's Avatar
LD85
I mounted some Infinity speakers in my door and mounted them to a piece of plywood for clearance on the window, I THINK they wer 6.5"'s.
But mine is an 85
Old Oct 3, 2004 | 09:14 PM
bogus's Avatar
bogus
A baffle is a generic term for any adaptor plate that fits a speaker into a hole.
As for dimentions...
These are rough, at best... and requires some fitting to make it right.
What I did was measure the depression where the old speakers went and started from there.
Approx. 11" x 8.5" - this is a 1/4" thick berch plywood. 2 angled pieces, .75" x 2" x 6". The angled pieces are mounted flush with the top.
You WILL have to cut the rocker cover to snug fit this in. I plan on working on this some more this week. I will update things with some pics.
To Speaker fitment question?
