Volt Meter...
Old Sep 30, 2004 | 11:26 AM
bigdreams65's Avatar
bigdreams65
Default Volt Meter...
OK... I just got back from a nice 600+ mile run and while driving to work today I noticed the speedometer is blinking (lite/dark lite/dark).. I set the guages to the volts and it's bouncing between 13 and 16 up and down. It never settles on one number..
Is this normal? I don't remember seeing it do tis before, but I never realley keep the guage set there either.
any help would be appreciated...
Thanks..
Old Sep 30, 2004 | 12:16 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
It's not normal with my car. Sorry I can't help more than that though.
Old Sep 30, 2004 | 12:20 PM
Jet-Jock's Avatar
Jet-Jock
I would say no that is not normal. It's usually an indication of a bad or loose ground connection at the battery. The trip may have loosened it some.
Remove your ground cable, check and clean if corroded and re-torque to 15Nm. It should stop.
Old Sep 30, 2004 | 12:23 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
I suspect the voltage regulator inside the alternator is bad.
The normal reading should range from 13 to 14.5volts.
If you're getting 16v or higher readings, eventually you'll overvoltage charge the battery and cook the battery itself. (I've had this problem before, where I was getting a 24v output to the battery. The battery lasted about 1 hour)
Old Sep 30, 2004 | 12:30 PM
redwing76's Avatar
redwing76
24v for an hour? What a way to go.
Old Sep 30, 2004 | 01:13 PM
bogus's Avatar
bogus
I agree with the recommendations above... check the battery connections first, it's cheap, needs to be done, why not?
But I suspect it is a dying alternator.
Old Sep 30, 2004 | 01:46 PM
bigdreams65
Thanks everyone.. I will make an appointment at my dealer and have him check the alternator and regulator.. Thank god I have a warrenty on this stuff..
Thanks again..
Old Sep 30, 2004 | 02:23 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Ntohing against your dealer, but take it to O'Reilly, AutoZone, or somewhere similar. They will check it for free, then, if you prefer, you can take it to dealer for repair. Too many horror stories on this forum (including mine) to ever trust a dealer completely. Even if it's under warranty, you'll go in with some information for them.
To Volt Meter...
